RASPBERRY Pi Camera Module V2
Octoprint works without camera normal, if I attach camera - The OctoPrint server is currently not running.
pi@octopi:~ $ vcgencmd get_camera
supported=1 detected=1 -
Turn on P1 Camera in PuTTy
Flash image, update to newest upgrade..
Logs (/var/log/webcamd.log
, syslog, dmesg, ...)
CAMLOG
Starting up webcamDaemon...
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
http options: -w ./www-octopi -n
<13>Mar 13 22:54:23 pi: Starting Raspberry Pi camera
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_raspicam.so -fps 10
MJPG Streamer Version: git rev: 8cc9d22c1e79905d529a248ccf05bbf0625e0bf3
i: fps.............: 10
i: resolution........: 640 x 480
i: camera parameters..............:
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
o: HTTP Listen Address..: (null)
i: Starting Camera
Encoder Buffer Size 81920
camera: auto
<13>Mar 13 22:53:36 pi: Starting Raspberry Pi camera
i: Starting Camera
camera: auto
No camera detected, trying again in two minutes
HAPROXY LOG
Mar 13 22:54:22 octopi haproxy-systemd-wrapper[550]: haproxy-systemd-wrapper: executing /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds
Mar 13 22:54:22 octopi haproxy-systemd-wrapper[550]: [WARNING] 071/225422 (551) : Setting tune.ssl.default-dh-param to 1024 by default, if your workload permits it you should set it to at least 2048. Please set a value >= 1024 to make this warning disappear.
Mar 13 22:53:50 octopi haproxy-systemd-wrapper[489]: haproxy-systemd-wrapper: executing /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds
Mar 13 22:53:50 octopi haproxy-systemd-wrapper[489]: [WARNING] 071/225350 (491) : Setting tune.ssl.default-dh-param to 1024 by default, if your workload permits it you should set it to at least 2048. Please set a value >= 1024 to make this warning disappear.
Jul 1 17:09:21 octopi haproxy-systemd-wrapper[482]: haproxy-systemd-wrapper: executing /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds
Jul 1 17:09:21 octopi haproxy-systemd-wrapper[482]: [WARNING] 181/170921 (484) : Setting tune.ssl.default-dh-param to 1024 by default, if your workload permits it you should set it to at least 2048. Please set a value >= 1024 to make this warning disappear.
Jul 1 17:17:29 octopi haproxy-systemd-wrapper[477]: haproxy-systemd-wrapper: executing /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds
Jul 1 17:17:30 octopi haproxy-systemd-wrapper[477]: [WARNING] 181/171730 (479) : Setting tune.ssl.default-dh-param to 1024 by default, if your workload permits it you should set it to at least 2048. Please set a value >= 1024 to make this warning disappear.
Jul 1 17:28:08 octopi haproxy-systemd-wrapper[474]: haproxy-systemd-wrapper: executing /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds
Jul 1 17:28:09 octopi haproxy-systemd-wrapper[474]: [WARNING] 181/172809 (475) : Setting tune.ssl.default-dh-param to 1024 by default, if your workload permits it you should set it to at least 2048. Please set a value >= 1024 to make this warning disappear.
Jul 1 18:14:28 octopi haproxy-systemd-wrapper[474]: haproxy-systemd-wrapper: SIGTERM -> 480.
Jul 1 18:14:28 octopi haproxy-systemd-wrapper[474]: haproxy-systemd-wrapper: exit, haproxy RC=0
Jul 1 18:15:08 octopi haproxy-systemd-wrapper[446]: haproxy-systemd-wrapper: executing /usr/sbin/haproxy -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid -Ds
Jul 1 18:15:08 octopi haproxy-systemd-wrapper[446]: [WARNING] 181/181508 (447) : Setting tune.ssl.default-dh-param to 1024 by default, if your workload permits it you should set it to at least 2048. Please set a value >= 1024 to make this warning disappear.
