I try to connect my Ender 3 printer to OctoPrint and it refuses to connect.
I have tried many different ports, updating drivers, using different drivers, updating bit rate, pretty much everything I could find.
No I don't get how to run it in safe mode, I dont think this would solve the problem anyways as I have tried in two other slicers and they have refused to connect as well.
Did not try.
octoprint-systeminfo-20220224213508.zip (19.9 KB)
Performing autodetection with 7 port/baudrate candidates: COM7@115200, COM7@250000, COM7@230400, COM7@57600, COM7@38400, COM7@19200, COM7@9600
Trying port COM7, baudrate 115200
Connecting to port COM7, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0x24fb1ca0460, open=True>(port='COM7', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Handshake attempt #2 with timeout 2.0s
Handshake attempt #3 with timeout 2.0s
Trying port COM7, baudrate 250000
Trying port COM7, baudrate 230400
Trying port COM7, baudrate 57600
Trying port COM7, baudrate 38400
Trying port COM7, baudrate 19200
Trying port COM7, baudrate 9600
Changing monitoring state from "Detecting serial connection" to "Error"
Windows 10 64 bit, Ender 3, Lastest Ender 3 firmware as far as I can tell, (I was using Cura USB connections when that suddenly stopped working) OctoPrint 1.7.3, Chrome, Python 3.10.2
