First of all I'm depressed and forget easily. Including my account passwords, google cant seem to get them into JuiceSSH properly.
It literally started happening spontanusly but within 48 hours of updates. I had the best run of good prints and now 1/8 success. Early problems said that my printer requested the same line over and over. Later I caught OP restarting corelating with a freeze of printer movement. Now it resets by itself, not even connected to printer, not doing anything...
I tried to roll-back update (easy to go foward, going back takes a computer scientist).
I swapped the USB port.
I reduced baud to 56k.
Enabled Serial.log - oh I'm scared it logs everything!!
Removed the USB keyboard that was assotiated with the plugin.
Safe mode, thx for reminding me.
Remove all my hair.
Discover serial.log is useless, it is cleared on every boot so a post-mortem is impossible - WTG....
Find out it isn't in safe mode for some reason tyring again, ok now no plugins.
Giving up on OP, using SD card. Problem kind of solved.
Yep - made issue worse - it reset about every 15 minutes even with no provocation.
Nope.
octoprint-systeminfo-20211104183020.zip (502.9 KB)
1.7.2 (i want to go back to 1.7.1), no idea what octopI version, fw is marlin 2091 and i made many numeric changes to cfg files, browser chrome, windows 10"pro", the pi was put on the Raspi 4 with genuine PSU a few months ago, in octoprint I made much use of USB keyboard but kept plugins down to a few. I just added a new E stepper, a bigass 4248 and I am allotting it 1450ma. It's running spreadCycle and rest of steppers on stealth. Linear advance used, umm. Oh I got a camera on it, i made sure I got connections on good then used sticky ass masking tape for good measure. (not wimpy true masking tape, this thing will pull hairs) and camera serves out to blueIris 4 on my PC. Still streaming - nice.
Did I mention it did a fantastic job on 7 good prints before it shit the bed?
I am feeling heavily this is HW, now that it got worse in safe mode - in fact it rebooted into it again because of "error loading/booting/starting" i forget words. It failed to load so reloaded into safe mode a few times, now it did it again and it's running plugs ok but it'll reset by time I'm done with this.
