Restore is not working. Getting the message "Not an OctoPrint backup, lacks metadata.json"
I originally created the backup using Octoprint 1.5.3 using Safari web browser. I then downloaded the backup to my iMac.
I then flashed my Raspberry Pi SD card with the latest Octopi image. Once flashed I set up Octoprint and upgraded to 1.5.3 and then attempted to restore. When the restore file was downloaded to my iMac it automatically unzips the file. When I realised that Octoprint Restore wanted a zip to upload I zipped the files myself and then attempted the restore. The restore fails with the message "Not an OctoPrint backup, lacks metadata.json" I can confirm the metadata.json does exist and is part of the zipped file.
I had a look online and saw the web browser might cause issues. So I connected to Octoprint via the Chrome web browser and tried to perform a restore with the same zipped backup. I got the same error message.
I then tried creating a new backup via the Chrome browser. This time the backup zip remained a zip and was not unpacked like with Safari. When I attempted the restore with this new back up zip the restore process worked perfectly.
So not sure what Safari is doing but I would really like to be able to backup with the original backup from Safari, why can't I simply zip the files again and restore? Why is the metadata.json not being seen?
I did further testing and I unzipped the working backup on my iMac and then zipped it again. After this process the restore will then fail again. I have also tried zipping the file with Winzip on a Windows PC but the restore will still fail with the same message.
Did not test
Complete Logs
N/A
1.5.3, 18.0, Safari and Chrome OSX 10.15.7
