Octoprint returns 403 error in Unity when attempting to connect
I have 2 instances of octoprint integrated with my unity project (printer2). printer 1 works but printer2 keeps returning a 403 error. it seems to be the octoprint's issue.
checked the unity code, checked the api key, tried to run octoprint with CORS
yes
no
octoprint-systeminfo-20240904141408.zip (148.6 KB)
I'm using two raspberry pis connected by ethernet
This error code is forbidden access. If you look in your tonado.log, you will see some warnings with the 403 status code.. Looks like you maybe have a wrong api key entered somewhere.
found the issue after searching unity and found a wrong api key, thank you!
