Octoprint interface is really slow. I open a new window and it works for maybe a minute, then it gets really slow, won't load anything, etc. When I refresh the page from that state, it says "loading failed: socket connection failed..." Opening a new tab will allow it to load, but refreshing the page does not.
I am stuck on what to do. I haven't had this issue before.
Logs (syslog, dmesg, ... no logs, no support) octolog.log (122.9 KB)
Attached is my octoprint log.
I'm running Octopi on a Pi 3 Model B Rev 1.2, and the firmware version is 1.4.0. Trying to connect from my computer running chrome.
I have similar issues. After some time running really smoothly all my octoprint Installations on different Pi are really slowly now. On one (Pi 4) it is not even booting up anymore. Version 1.5.3
The remaining one - slow but at least working:
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_6) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.0.3 Safari/605.1.15
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: false
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 917016576
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.17.0
env.python.pip: 19.3.1
env.python.version: 2.7.16
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.3
printer.firmware: Marlin 1.1.0-RC8 (Github)
Hello!
I had the same problem. After a while the web interface starts getting sluggish up to a point that is unusable. In my case the culprit was the Printer Notifications windows. Pressing the 'clear notifications' button restored the usability for a while.
I finally disabled the panel completely, it can be done from the settings / printer notifications, uncheck the "enable" box.
