Octoprint says no serial port available
Octoprint shows this message:
No serial port found, are you sure your printer is physically connected and supported? Try [refreshing](javascript:void(0)) and if that doesn't help please see the FAQ.
Turned octoprint off and on...several times. Sometimes it would start and run normally for a few minutes then shut down again saying there was no serial port again
yes
no
octoprint-systeminfo-20240507075909.zip (72.3 KB)
Octoprint Version 1.10.0 Pi VErsion 1.8.5, Ender3v2/Sprite extruder, [Ender3V2-427-BLTUBL-MPC-20240125.bin] running PETG at 240/70
Have you tried different USB cables to connect the printer? Did you try anything from the FAQ linked?
I may have discovered the cause. The connection from the pi to the printer was a little sketchy. I made sure that it was secure and printed in pla as a first test. When that comes out I'll try another
petg in case heating was the issue. So far it's been happy for the last 2 hours and 2 more to go. So it looks very promising
Thanks all
I wonder if it's possible to create a "serial port stress test" that sends a battery of commands and verifies the results. I don't know if plugins can feed serial data fast enough.
