| Recv: Error:!! STOP called because of BLTouch error - restart with M999
| Recv: Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
There error during reading the serial port:
2023-03-10 08:09:24,686 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 3997, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 6672, in readline
c = self.read(1)
File "/home/pi/oprint/lib/python3.7/site-packages/serial/serialposix.py", line 596, in read
'device reports readiness to read but returned no data '
serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2023-03-10 08:09:24,725 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
Guess ill have to get a better case for the pi, but hows the bed therm not working? it says its at 27 C. I also got the systeminfobundle before the ui crashed. Sometimes it lets me access it and sometimes it dosent, whenever i try to get to the reboot into safe mode option, it dosent work. I was only able to get the systeminfo bundle.
BLTouch errors are usually caused by loose or noisy connections (ie. check all the wiring, move it away from electrical noise such as motors), or by the bed being too un-level whilst probing. You should probably watch the printer to see if you can figure out where the BLTouch error is coming from - if it always happens when probing at the same place for example.
In the logs there is no indication of the server crashing, it looks to shutdown & restart normally. I would try safe mode, you can do it via SSH if the UI is unavailable - the link shows you how. It could be that you have a plugin triggering a shutdown.
I checked the connections and it looks fine to me, but how can I find the plugin that's causing this? I have more than 5 and I don't want to scrape through each one
I actually was able to get into safe mode earlier, and it seemed to not crash.
(earlier it would crash as soon as the server started but I was able to get in before it had the chance to)
One way you can reduce the number of plugins you need to test is by disabling half of them, testing, then either enabling/disabling another half each time and you can locate the problem plugin efficiently. There's no indication in the log of why it is shutting down, only that it is doing so.
While it is unlikely that the firmware on the printer would cause the OctoPrint server to crash, the onus is on you to determine if the firmware version is causing you problems.
Since the build date is almost one and a half years ago, I'm guessing there are more up-to-date versions available for the Creality Ender 3 V2. Be aware that some of Creality's firmware has "challenges" that may be worse than what you are running now.
The thing is that im actually using jyres firmware, a modded version of crealitys, i wasnt able to run crealitys OG firmware because it made my printer crash as soon as i did anything level related on it, so i used jyres instead
Disable or remove OctoEverywhere if it is causing problems. Once you get a stable system, you can figure out how to add back the functionality that plugin provides. I'd open an issue on the plugin's website. I see on that site that the newest release was yesterday (10 Mar 2023).
I can't give you any advice on firmware for Creality's printers as I don't (and won't) own one. All I can suggest is that whatever firmware you use, understand where it comes from and how it is supported. If the firmware you are currently uses has a web site or a project page then check there to see if what you have is the latest and greatest.
Seems that octoeverywhere was the issue, ive contacted the dev to ask him how I can fix this. One thing I now have is octoprint telling me that octolapse didn't capture any frames, I guess ill need to figure that out
