I’m getting the ‘Octoprint server is currently not running l’ message when trying to connect. It was working fine before going to bed, then it was giving me this error when I woke up. The printer was running just fine all night with no glitches.
I’ve restarted multiple times.
I’ve attempted to get a log, but WinSCP wasn’t connecting either.
Using pi4
use this as an easy script, service octoprint restart, I put those 3 words in a nano file on my home directory. I named mine "opi.sh", so all I have to do is > ./opi.sh and it restarts the service. You can do something like that for any other service you may be having issues with. I built the same type of file for "update" "upgrade" and "autoremove". You will have to chown & chmod all these .sh files.
I hope that's not UberGeek enough to scare you. I'll give you a "guideline" (like pirates) not the step by step. I've read the fine manual, you should too! IMHO not a noob flame!
I think the problem was the newest update. Or possibly the update paired with some plugin. I re loaded from scratch, updated when the update notification popped up, and got the same problem after a couple hours.
I started from scratch again but this time didn’t do the update and it’s been working great since.
Well, it was working fine until I replied. Now it’s back to saying the same thing.
Found the logs finally... it's saying that it's getting SSL CertVerificationError
So you don't have the same problem?
Since you got a different issue please open a new thread and attach a systeminfo bundle.
You can't just tell us it doesn't work, there are no errors and don't upload any logs.
What are we supposed to do with that information?
