Octoprint server doesn't start. Raspberry is connected to the network but if I go on the page where I could control the printer there is the message "The OctoPrint server is currently not running" with the suggestions.
I used to unplug the raspberry after every print, I didn't know that was better shutdown the server before because until today evertything worked great.
I opened the log file but I don't understand the problem. There are many "null" (only opening the file with notepad++) that I think are the problem but I don't know how to solve.
I think that the only information needed is the log file, if not I'll give you other informations. octoprint.log (69.5 KB)
Yes I tried to refresh obviously. My supplier for raspberry is 5 Volt 2.1 Ampere and the webcam is temporarily not plugged,
Before you replied I tried to connect the raspberry to another network so I modified the file octopi-wpa-supplicant.txt in the sd with my values but nothing happened (it was visible in the network but the server didn't start).
I read your suggestion so I tried to connect it to internet to access by SSH but it wasn't recognized so I put sd in pc and I read a message that it wasn't readable so I needed to repair the sd. After I done it, the file octopi-wpa-supplicant.txt was gone and I think other files too.
I don't know what happened but I'm scared I have to starting over on with octoprint losing all my plugins and settings.
The specification for a Raspberry Pi 3B is 5V @ 2.5A so your power adapter should be replaced. Note that your webcam will also draw additional power as well as other things you plug into the USB ports later. You might as well fix this early.
I think you're about the third person today whose Windows prompted them to format a perfectly-good ext4 partition.
don't EVER just disconnect or turn off power to the pi. it corrupts files on the sd card. you have to run the shutdown from the octoprint web interface, or ssh in and run "sudo shutdown -h now" then unplug power after you give it a minute or so to perform it's shutdown.
