after tryind to install the plugin flowspeedrename, my server isn't running
tried apt-get update/upgrade, then it starts once in safe mode but after still have the message that server isnt running
i don't know how to force safe mode from ssh
Complete Logs
yes problem appears after this plugin installation
i tried your solution and i have rm: cannot remove '/home/pi/.octoprint/plugins/setup.py': No such file or directory
it is possible to fix it directly on the sd card?
Great news.
So it seems OctoPrint thought that it was a single file plugin and put just the setup.py, rather than the full package. Have you got a link to the plugin in question?
I don't know what went wrong here on install either, but I've just pushed a commit that will make sure only such files are actually loaded that look like plugins (= any of the defined control properties are detected in the file's AST). Will be shipped with OctoPrint 1.6.0 (NOT 1.5.0 which just entered RC phase yesterday).
