Hello all, experiencing an issue that is new to me. Thought I would check here before I rebuild my server.
I can SSH into Pi but when I attempt to visit octopi.local in a browser I see " The OctoPrint server is currently not running." System was running, I manually started a print from the printer's interface while Octopi was connected via USB, but not actually "connected" in the Octoprint web interface. When the short print (bed level check) was done I logged into Octoprint and, since it had been several weeks since I've used it, decided I would reboot. After reboot I can still use SSH but the Octoprint server is not running, and will not start.
I tried ps -ef | grep -i octoprint | grep -i python but there is no response, SSH (via Putty) prints a carriage return.
I've looked at ~/.octoprint/logs/octoprint.log and can see error messages, but not sure what would be causing them.
I've tried to restart the service several times with sudo service octoprint restart, but the terminal prints a carriage return within 1 second and nothing seems to happen.
I've tried to start the server in safe mode using both the command line method, as well as adding startOnceInSafeMode: true to the server block of config.yaml, but neither were successful.
Octoprint.log attached >> octoprint.log (11.2 KB)
RPi 3B rev 1.2
OctoPrint v1.4.0
OctoPi v0.17.0
Printer is a Creality Ender 3 Pro, been using this Octoprint setup on the same Pi for at least five months, and have recently used extensively to print COVID-19 supplies.
Printer firmware is Creality v1.1.6.2.
I've tried connecting on two different Win10 64-bit machines with latest Chrome browsers, and also tried with Microsoft Edge browser on one. Additionally, I've tried connecting with OctoRemote, which has never had an issue before, but it does not succeed.
