Octoprint server refuses to run all of a sudden
I cannot get the Octoprint server to get up and running. It's always " The OctoPrint server is currently not running". Happened all of a sudden, my last print wasn't even finished when I noticed I couldn't reach the server. I have a raspberry pi W2 along on the same network with another octoprint server and it works flawlessly. I did not change anything on the setup.
Very reacheable by SSH.
ps -ef | grep -i octoprint | grep -i python ==> nothing
Reboot by ssh several times, hard reboot as well ==> no change
Octoprint safemode ==> -bash: octoprint: command not found
octoprint config set --bool server.startOnceInSafeMode true
Nope
RPi 3b
OctoPrint version : 1.7.3
OctoPi version : 0.17.0
Log:
2023-06-26 12:54:34,624 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2023-06-26 12:54:34,629 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2023-06-26 12:54:34,630 - octoprint.server - INFO - OctoPrint 1.7.3
2023-06-26 12:54:34,637 - octoprint.plugin.core - INFO - 35 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Bed Visualizer (1.1.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_bedlevelvisualizer
| BLTouch Plugin (0.3.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_BLTouch
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| Dashboard (1.19.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_dashboard
| Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| DisplayLayerProgress Plugin (1.28.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_DisplayLayerProgress
| Enclosure Plugin (4.13.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_enclosure
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| Event Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/eventmanager
| *Filament Sensors Revolutions (1.0.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_filamentrevolutions
| File Check (2021.2.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| FileManager (0.1.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_filemanager
| Firmware Check (2021.10.11) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| GcodeEditor (0.2.12) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_GcodeEditor
| LED Strip Control (0.3.7) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_LEDStripControl
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| M117PopUp (0.6.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_M117PopUp
| OctoPrint-WideScreen (0.1.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_widescreen
| Pi Support Plugin (2022.3.28) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| PrintTimeGenius Plugin (2.2.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_PrintTimeGenius
| !Remove /dev/ttyS* ports (0.1.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_remove_ttys_ports
| Sidebar Webcam (0.1.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_webcamSB
| Simple Emergency Stop (1.0.5) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_simpleemergencystop
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| Tab Order (0.5.12) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_taborder
| *Terminal Commands (0.1.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_TerminalCommands
| Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
2023-06-26 12:54:34,659 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 917016576
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.17.0
| throttle_state: '0x80008'
| python:
| pip: 21.3.1
| version: 3.7.3
| virtualenv: /home/pi/oprint
2023-06-26 12:54:34,660 - octoprint.server - INFO - ------------------------------------------------------------------------------
2023-06-26 12:54:41,325 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'version': '1.7.3', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '21.3.1', 'cores': 4, 'freq': 1400.0, 'ram': 917016576, 'pi_model': 'Raspberry Pi 3 Model B Plus Rev 1.3', 'octopi_version': '0.17.0', 'plugins': 'webcamsb:0.1.8,widescreen:0.1.4,taborder:0.5.12,simpleemergencystop:1.0.5,printtimegenius:2.2.8,m117popup:0.6.2,ledstripcontrol:0.3.7,gcodeeditor:0.2.12,filemanager:0.1.6,enclosure:4.13.2,dashboard:1.19.8,bltouch:0.3.4,displaylayerprogress:1.28.0,bedlevelvisualizer:1.1.1'}
2023-06-26 12:55:05,992 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 5961644, 'printer_state': 'OPERATIONAL'}
2023-06-26 12:59:48,482 - octoprint.server.util.flask - INFO - Passively logging in user Nereus from ::ffff:10.27.254.244
2023-06-26 12:59:48,484 - octoprint.access.users - INFO - Logged in user: Nereus
2023-06-26 12:59:49,200 - octoprint.server.util.flask - INFO - Passively logging in user Nereus from ::ffff:10.27.254.244
2023-06-26 12:59:49,200 - octoprint.access.users - INFO - Logged in user: Nereus
2023-06-26 12:59:49,381 - octoprint.server.util.flask - INFO - Passively logging in user Nereus from ::ffff:10.27.254.244
2023-06-26 12:59:49,382 - octoprint.access.users - INFO - Logged in user: Nereus
2023-06-26 12:59:49,956 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.27.254.244
2023-06-26 12:59:50,095 - octoprint.server.util.flask - INFO - Passively logging in user Nereus from ::ffff:10.27.254.244
2023-06-26 12:59:50,096 - octoprint.access.users - INFO - Logged in user: Nereus
2023-06-26 12:59:53,423 - octoprint.server.util.sockjs - INFO - User Nereus logged in on the socket from client ::ffff:10.27.254.244
2023-06-26 12:59:55,746 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_now': False, 'throttled_past': False, 'throttled_mask': 524296, 'throttled_voltage_now': False, 'throttled_voltage_past': False, 'throttled_overheat_now': False, 'throttled_overheat_past': False}
2023-06-26 12:59:59,037 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2023-06-26 12:59:59,494 - octoprint.server.util.flask - INFO - Passively logging in user Nereus from ::ffff:10.27.254.244
2023-06-26 12:59:59,495 - octoprint.access.users - INFO - Logged in user: Nereus
2023-06-26 12:59:59,637 - octoprint.server.util.flask - INFO - Passively logging in user Nereus from ::ffff:10.27.254.244
2023-06-26 12:59:59,638 - octoprint.access.users - INFO - Logged in user: Nereus
2023-06-26 12:59:59,680 - octoprint.plugins.tracking - INFO - Sent tracking event webui_load, payload: {'browser_name': 'Firefox', 'browser_version': '114.0', 'os_name': 'Windows', 'os_version': '10'}
2023-06-26 13:02:18,199 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_now': False, 'throttled_past': False, 'throttled_mask': 524288, 'throttled_voltage_now': False, 'throttled_voltage_past': False, 'throttled_overheat_now': False, 'throttled_overheat_past': False}
2023-06-26 13:09:34,626 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2023-06-26 13:10:06,140 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 5962544, 'printer_state': 'OPERATIONAL'}
2023-06-26 13:22:18,235 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_now': False, 'throttled_past': False, 'throttled_mask': 524296, 'throttled_voltage_now': False, 'throttled_voltage_past': False, 'throttled_overheat_now': False, 'throttled_overheat_past': False}
2023-06-26 13:24:34,627 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2023-06-26 13:25:06,322 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 5963444, 'printer_state': 'OPERATIONAL'}
2023-06-26 13:39:34,629 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2023-06-26 13:40:06,205 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 5964344, 'printer_state': 'OPERATIONAL'}
2023-06-26 13:47:18,644 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_now': False, 'throttled_past': False, 'throttled_mask': 524288, 'throttled_voltage_now': False, 'throttled_voltage_past': False, 'throttled_overheat_now': False, 'throttled_overheat_past': False}
2023-06-26 13:49:48,019 - octoprint.plugins.dashboard - INFO - GcodePreProcessor started processing.
2023-06-26 13:49:48,025 - octoprint.plugins.DisplayLayerProgress - INFO - FilePreProcessor. Checking LayerExpressions.
2023-06-26 13:49:48,027 - octoprint.plugins.DisplayLayerProgress - INFO - FilePreProcessor. LayerExpression valid. Start processing...
2023-06-26 13:50:27,957 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Nereus_Ammo_Box_HandX5.gcode
2023-06-26 13:50:37,438 - octoprint.plugins.DisplayLayerProgress - INFO - Store layer count in MetaFile
2023-06-26 13:50:51,294 - octoprint.plugins.DisplayLayerProgress - INFO - Did NOT reading total height from MetaFile, because analyse was done for not selected file. Current: 'Nereus_Hook2.gcode' Analyse for: 'Nereus_Ammo_Box_HandX5.gcode'
2023-06-26 13:50:51,304 - octoprint.plugins.dashboard - INFO - GcodePreProcessor found layers: 268
2023-06-26 13:50:51,305 - octoprint.plugins.dashboard - INFO - GcodePreProcessor found filament changes: 0
2023-06-26 13:50:51,305 - octoprint.plugins.dashboard - INFO - GcodePreProcessor saving layer count in file metadata
2023-06-26 13:51:03,903 - octoprint.plugins.DisplayLayerProgress - INFO - Store layer count in MetaFile
2023-06-26 13:51:04,143 - octoprint.filemanager.analysis - INFO - Analysis of entry local:Nereus_Ammo_Box_HandX5.gcode finished, needed 36.19s
2023-06-26 13:51:23,423 - octoprint.plugins.DisplayLayerProgress - INFO - Did NOT reading total height from MetaFile, because analyse was done for not selected file. Current: 'Nereus_Hook2.gcode' Analyse for: 'Nereus_Ammo_Box_HandX5.gcode'
2023-06-26 13:51:24,136 - octoprint.plugins.DisplayLayerProgress - INFO - Store layer count in MetaFile
2023-06-26 13:51:34,061 - octoprint.plugins.DisplayLayerProgress - INFO - Did NOT reading total height from MetaFile, because analyse was done for not selected file. Current: 'Nereus_Hook2.gcode' Analyse for: 'Nereus_Ammo_Box_HandX5.gcode'
2023-06-26 13:52:18,728 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_now': False, 'throttled_past': False, 'throttled_mask': 524296, 'throttled_voltage_now': False, 'throttled_voltage_past': False, 'throttled_overheat_now': False, 'throttled_overheat_past': False}
2023-06-26 13:54:34,631 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2023-06-26 13:56:38,095 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from online to offline
2023-06-26 13:56:38,097 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is not working
2023-06-26 13:56:38,098 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is not working
2023-06-26 14:09:34,633 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2023-06-26 14:10:35,097 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:10.26.76.137
2023-06-26 14:10:49,177 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:10.27.254.244
2023-06-26 14:24:34,635 - octoprint.server.heart
What is the output of df -h when you are ssh'd in?
It's solved (sort of...), turns out my SD card got bricked, like it had no space left all of a sudden, and I cannot even read it on another machine...
Starting the server via "octoprint" is deprecated, please use "octoprint serve" from now on.
2023-06-30 13:41:01,332 - octoprint.settings - ERROR - Could not write test file to /home/pi/.octoprint/logs/.testballoon.txt
OSError: [Errno 28] No space left on device
During handling of the above exception, another exception occurred:
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/settings.py", line 2268, in _validate_folder
f.write("test")
2023-06-30 13:41:01,335 - octoprint.startup - CRITICAL - Could not initialize se ttings manager: Folder at /home/pi/.octoprint/logs doesn't appear to be writable , please fix its permissions
2023-06-30 13:41:01,336 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
Could not initialize settings manager: Folder at /home/pi/.octoprint/logs doesn' t appear to be writable, please fix its permissions
