More of an FYI to help others and possible prevent it happening in the future. It took me about a week (20 mins daily here and there) of delving to find the problem and solve it. I will attempt to recreate it if I can...
What WAS the problem?
I will attempt to explain this the best I can.
Server running 1.8.1 on a Raspberry Pi 4b 2Gb, 32Gb SD
After installing plug-in updates to "OctoPrint-ExtraFileInfo-1.0.0" and "OctoPrint-PiSupport-2022.6.13", Octoprint service failed to restart, even rebooting Raspberry Pi failed to restart service.
What did you do to try to solve it?
ps -ef | grep -i octoprint | grep -i python Yielded Nothing
sudo service octoprint restart Yielded Nothing
Server would not start to allow the ability to download the System Info or Logs as Web interface would not load.
octoprint systeminfo Yielded nothing
octoprint systeminfo . Also yielded nothing
pi@octopi: ~/oprint/bin/octoprint
Starting the server via "octoprint" is deprecated, please use "octoprint serve" from now on.
2022-06-17 19:53:52,214 - octoprint.startup - INFO - *********************************************************************** *******
2022-06-17 19:53:52,216 - octoprint.startup - INFO - Starting OctoPrint 1.8.1
2022-06-17 19:53:52,217 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2022-06-17 19:53:52,217 - octoprint.startup - INFO - Reason for safe mode: problem during last startup
2022-06-17 19:53:52,217 - octoprint.startup - INFO - *********************************************************************** *******
2022-06-17 19:53:52,481 - octoprint.util.connectivity.connectivity_checker - INFO...
2022-06-17 19:53:54,088 - octoprint.server - ERROR - Could not instantiate user manager octoprint.access.users.FilebasedUser Manager, falling back to FilebasedUserManager!
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/init.py", line 553, in run
userManager = clazz(groupManager)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/access/users.py", line 508, in init
self._load()
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/access/users.py", line 512, in _load
data = yaml.load_from_file(path=self._userfile)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/yaml.py", line 14, in load_from_file
return load_from_file(file=f)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/yaml.py", line 28, in load_from_file
return yaml.load(file, Loader=SafeLoader)
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/init.py", line 112, in load
loader = Loader(stream)
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/loader.py", line 34, in init
Reader.init(self, stream)
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/reader.py", line 85, in init
self.determine_encoding()
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/reader.py", line 124, in determine_encoding
self.update_raw()
File "/home/pi/oprint/lib/python3.7/site-packages/yaml/reader.py", line 178, in update_raw
data = self.stream.read(size)
File "/home/pi/oprint/lib/python3.7/codecs.py", line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
File "/home/pi/oprint/lib/python3.7/encodings/utf_8_sig.py", line 69, in _buffer_decode
return codecs.utf_8_decode(input, errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xfe in position 1: invalid start byte
I figured it was a problem with the Python script for UTF-8, so I performed an APT-GET update and upgrade, this completed but did not fix the problem.
I did a downgrade to v 1.8.0 of Octoprint using:
pip install --force-reinstall OctoPrint==1.8.0 --no-cache-dir
Afterwards, restarting had no effect
It took me a bunch of Gooleing to find what "octoprint.access.users.FilebasedUser" referenced, the users.yaml file. I opened the file via SSH (not my preferred method)
pi@octopi:~/.octoprint $ nano users.yaml
the file appeared as either binary or possibly in some kind of character language like Chinese or Japanese? Since the file contains user PW data, it will not be "displayed" or uploaded.
on my Windows machine I extracted the users.yaml from an old backup and proceeded to rename the bad yaml file and SCP (pscp.exe) the backup to my pi:
pi@octopi:~/.octoprint $ mv users.yaml users.yaml.corrupt
C:\Users\...\Downloads>pscp C:\temp\users.yaml.frombackup pi@octopi:.octoprint/users.yaml
pi@octopi's password:
users.yaml.frombackup | 0 kB | 0.3 kB/s | ETA: 00:00:00 | 100%
The service finally started and I was able to once again access the web interface of v1.8.0
Yes via command line, unable to load server
pi@octopi:/home $ ~/oprint/bin/octoprint safemode
Safe mode flag set, OctoPrint will start in safe mode on next restart.
You can download this in OctoPrint's System Information dialog ... no bundle, no support!) FUNNY as No Service Start, No Download system info!
this is the v1.8.0 system info file, I'll upload my v1.8.1 file after re-upgrading.
octoprint-systeminfo-20220620182522.zip (673.7 KB)
1.8.1 on a Raspberry Pi 4b 2Gb, 32Gb SD, downgraded to 1.8.0 during troubleshooting.
Kernel 5.10.103-v7l+
OctoPrint 1.8.0
Python 3.7.3
OctoPi 0.18.0
AnyCubic Mega Pro
Suggested change(s)?
Possibly remove the dependency on corrupted config file(s) for a "Super" Safe-Mode, to allow backup restoration.
