My Octoprint service (1.4.0) died after APT upgrade, it starts but imediately exits with ERRORCODE 0.
Service status -- Active: active (exited)
- I've searched all logs, but in APT log there is about 50 upgraded packages at one run - no luck to search here.
- I've tried to restart whole box/PC, tried to restart OctoPrint service.
- I've tried to search in Octoprint logs - nothing there.
- Checked /etc/default/octoprint and /etc/init.d/octoprint for changes made automaticaly with APT - nothing there.
- Tried to manually start Octoprint via source activate and octoprint serve -> log is attached. There is some error but it seems like some compatability issue and I don't understand that enough, but it looks most promising after all.
Now I'm definitely lost
Complete Logs
Octoprint logs: logs.zip (4.8 KB)
Service files: service.zip (2.4 KB)
Manual run terminal output: manual_run.log (11.4 KB)
OctoPrint ver.: 1.4.0 (upgrade to 1.4.1 always failed)
- installed manually step by step according to tutorial from Gina
OS: Ubuntu 20.04.1 LTS
System: x64 - Intel Celeron N3150 (NUC)
Aditional info:
pi@octobuntu:~/OctoPrint/venv/bin$ python --version
Python 2.7.18rc1
(venv) pi@octobuntu:~/OctoPrint/venv/bin$ python --version
Python 2.7.17
Virtual env Python version differs from system wide Python - I'don't know if that could lead to some problems.
You have a non-standard configuration. This is where i would start looking into your problem.
OSError: [Errno 13] Permission denied: '/media/ext/Octoprint'
I see you have Tasmota installed as well. Did you enable any of the options for off on disconnect or anything like that with a command to shutdown octoprint?
Yes both - autoconnect with delay and autodisconnect
To non standard config: system runs on SSD so timelapses were saved on external drive mounted on /media/ext/
I've tried to unsecurely fix the problem by chmod -R 777 /media/ext/ - but after service restart nothing changes
Tasmota plugin looks like a dead end, it is DIASABLED in safe mode so it doesn't start.
FIXED by Python3 migration script at: https://github.com/cp2004/Octoprint-Upgrade-To-Py3
Rebuild of venv helps and OctoPrint works again ...and as a bonus all is migrated to Python3
Thanks for help.
One of my many superpowers is helping people without knowing.... Great that your issue is solved, and the migration went successfully
First migration went wrong from this link: https://get.octoprint.org/py3/upgrade.py
But with freshly downloaded script from GitHub it worked like a charm.
I've already known that all plugins are already compatilbe with Python 3 and planned the migration, but with broken OctoPrint I had nothing to loose, so I gave it a shoot
Script done it's job and also (as side effect) fix broken venv - that was probably the main strange problem.
It often happens after an update, I am left here with 'run this reinstall OctoPrint command' in so many threads.
Similar to turn it off and on again
