Octoprint set up seems to be broken, the installed OS does not result in a running octoprint server
I followed the instructions here (OctoPrint.org - Download & Setup OctoPrint) 3 times and it does not result in a running octopring server.
There is no octoprint server set up in the downloaded image onto the disk
i did this i the past and it worked a charm. tonight was particularly frustrating.
i am running on a raspberry pi3
there is no .octoprint directory.
i cannot run in safe mode. there is no octoprint.
Just to be sure - you used this image, right?
https://github.com/OctoPrint/OctoPi-UpToDate/releases/download/1.0.0-1.10.1-20240514100113/octopi-1.0.0-1.10.1-20240514100113.zip
Sd card was bad. with new sd card it worked.
please close this issue.
