planetar:
sudo dmesg
here ae the result i got sorry idk how to copy it as preformatted text, and i'm using an ender 3v2
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.63-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1496 SMP Wed Dec 1 15:58:11 GMT 2021
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi Zero 2 W Rev 1.0
[ 0.000000] random: fast init done
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x13c00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x0000000017ffffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000017ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000017ffffff]
[ 0.000000] On node 0 totalpages: 98304
[ 0.000000] DMA zone: 864 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 98304 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 97440
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:F3:9F:1C vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=tty1 root=PARTUUID=242a9e16-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 306736K/393216K available (10240K kernel code, 1311K rwdata, 2948K rodata, 1024K init, 859K bss, 20944K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 32054 entries in 63 pages
[ 0.000000] ftrace: allocated 63 pages with 6 groups
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000024] Switching to timer-based delay loop, resolution 52ns
[ 0.000301] Console: colour dummy device 80x30
[ 0.001160] printk: console [tty1] enabled
[ 0.001231] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001288] pid_max: default: 32768 minimum: 301
[ 0.001499] LSM: Security Framework initializing
[ 0.001752] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001799] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.003244] cgroup: Disabling memory control group subsystem
[ 0.003524] CPU: Testing write buffer coherency: ok
[ 0.004030] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005272] Setting up static identity map for 0x100000 - 0x10003c
[ 0.005482] rcu: Hierarchical SRCU implementation.
[ 0.006410] smp: Bringing up secondary CPUs ...
[ 0.007566] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008824] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010120] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010277] smp: Brought up 1 node, 4 CPUs
[ 0.010330] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.010361] CPU: All CPU(s) started in HYP mode.
[ 0.010388] CPU: Virtualization extensions available.
[ 0.011256] devtmpfs: initialized
[ 0.028696] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.029030] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.029090] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.032331] pinctrl core: initialized pinctrl subsystem
[ 0.033539] NET: Registered protocol family 16
[ 0.037618] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.043341] audit: initializing netlink subsys (disabled)
[ 0.044259] thermal_sys: Registered thermal governor 'step_wise'
[ 0.045120] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.045347] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.045388] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.045689] Serial: AMBA PL011 UART driver
[ 0.064137] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.080145] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:08:00, variant start_x
[ 0.090156] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
[ 0.134339] Kprobes globally optimized
[ 0.139291] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.141706] SCSI subsystem initialized
[ 0.141976] usbcore: registered new interface driver usbfs
[ 0.142061] usbcore: registered new interface driver hub
[ 0.142153] usbcore: registered new device driver usb
[ 0.144134] clocksource: Switched to clocksource arch_sys_counter
[ 1.917877] VFS: Disk quotas dquot_6.6.0
[ 1.918020] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.918241] FS-Cache: Loaded
[ 1.918521] CacheFiles: Loaded
[ 1.929348] NET: Registered protocol family 2
[ 1.929572] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.930684] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.930772] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 1.930965] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.931092] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.931255] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.931316] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.931971] NET: Registered protocol family 1
[ 1.932800] RPC: Registered named UNIX socket transport module.
[ 1.932834] RPC: Registered udp transport module.
[ 1.932864] RPC: Registered tcp transport module.
[ 1.932892] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.934686] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.938494] Initialise system trusted keyrings
[ 1.938796] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.948379] zbud: loaded
[ 1.950463] FS-Cache: Netfs 'nfs' registered for caching
[ 1.951373] NFS: Registering the id_resolver key type
[ 1.951434] Key type id_resolver registered
[ 1.951463] Key type id_legacy registered
[ 1.951634] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.951669] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.952866] Key type asymmetric registered
[ 1.952899] Asymmetric key parser 'x509' registered
[ 1.952970] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.953010] io scheduler mq-deadline registered
[ 1.953040] io scheduler kyber registered
[ 1.955758] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.967303] Console: switching to colour frame buffer device 82x26
[ 1.974550] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 1.983122] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.986578] bcm2835-aux-uart 3f215040.serial: there is not valid maps for state default
[ 1.993416] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.996543] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 2.002713] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 2.020761] brd: module loaded
[ 2.035809] loop: module loaded
[ 2.040267] Loading iSCSI transport class v2.0-870.
[ 2.044655] libphy: Fixed MDIO Bus: probed
[ 2.047669] usbcore: registered new interface driver lan78xx
[ 2.050450] usbcore: registered new interface driver smsc95xx
[ 2.053062] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.783855] Core Release: 2.80a
[ 2.786502] Setting default values for core params
[ 2.789161] Finished setting default values for core params
[ 2.992179] Using Buffer DMA mode
[ 2.994759] Periodic Transfer Interrupt Enhancement - disabled
[ 2.997332] Multiprocessor Interrupt Enhancement - disabled
[ 2.999877] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.002363] Dedicated Tx FIFOs mode
[ 3.005194] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 93d14000 dma = 0xd3d14000 len=9024
[ 3.012109] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.022976] dwc_otg: Microframe scheduler enabled
[ 3.023050] WARN::hcd_init_fiq:457: FIQ on core 1
[ 3.027352] WARN::hcd_init_fiq:458: FIQ ASM at 807c9984 length 36
[ 3.031771] WARN::hcd_init_fiq:497: MPHI regs_base at 98810000
[ 3.036245] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.038557] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.040926] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.043249] Init: Port Power? op_state=1
[ 3.045498] Init: Power Port (0)
[ 3.048014] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.052595] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.055074] usb usb1: Product: DWC OTG Controller
[ 3.057429] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
[ 3.059817] usb usb1: SerialNumber: 3f980000.usb
[ 3.062922] hub 1-0:1.0: USB hub found
[ 3.065397] hub 1-0:1.0: 1 port detected
[ 3.068959] dwc_otg: FIQ enabled
[ 3.068972] dwc_otg: NAK holdoff enabled
[ 3.068983] dwc_otg: FIQ split-transaction FSM enabled
[ 3.069000] Module dwc_common_port init
[ 3.069301] usbcore: registered new interface driver usb-storage
[ 3.072075] mousedev: PS/2 mouse device common for all mice
[ 3.075712] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.080413] sdhci: Secure Digital Host Controller Interface driver
[ 3.082937] sdhci: Copyright(c) Pierre Ossman
[ 3.086166] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 3.089385] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.092183] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.095506] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.098425] hid: raw HID events driver (C) Jiri Kosina
[ 3.101156] usbcore: registered new interface driver usbhid
[ 3.103753] usbhid: USB HID core driver
[ 3.111268] Initializing XFRM netlink socket
[ 3.113876] NET: Registered protocol family 17
[ 3.116531] Key type dns_resolver registered
[ 3.119527] Registering SWP/SWPB emulation handler
[ 3.122057] registered taskstats version 1
[ 3.124414] Loading compiled-in X.509 certificates
[ 3.127570] Key type ._fscrypt registered
[ 3.129886] Key type .fscrypt registered
[ 3.132202] Key type fscrypt-provisioning registered
[ 3.146937] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.149401] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.156337] bcm2835-aux-uart 3f215040.serial: there is not valid maps for state default
[ 3.161897] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 86, base_baud = 50000000) is a 16550
[ 3.167905] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.172184] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.174863] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.204440] sdhost: log_buf @ (ptrval) (d3d13000)
[ 3.244604] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.248866] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.253051] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.255627] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.261114] of_cfs_init
[ 3.263671] of_cfs_init: OK
[ 3.267170] Waiting for root device PARTUUID=242a9e16-02...
[ 3.291296] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.295524] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.360188] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.369423] mmc0: new high speed SDHC card at address e624
[ 3.372947] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[ 3.378149] mmcblk0: p1 p2
[ 3.396023] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 3.398408] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.413579] mmc1: new high speed SDIO card at address 0001
[ 4.570359] EXT4-fs (mmcblk0p2): recovery complete
[ 4.578951] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.583382] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 4.593705] devtmpfs: mounted
[ 4.603041] Freeing unused kernel memory: 1024K
[ 4.606006] Run /sbin/init as init process
[ 4.608439] with arguments:
[ 4.608451] /sbin/init
[ 4.608461] with environment:
[ 4.608472] HOME=/
[ 4.608483] TERM=linux
[ 5.232014] systemd[1]: System time before build time, advancing clock.
[ 5.386531] NET: Registered protocol family 10
[ 5.390538] Segment Routing with IPv6
[ 5.462421] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.477606] systemd[1]: Detected architecture arm.
[ 5.548110] systemd[1]: Set hostname to .
[ 6.408508] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.425064] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.428852] systemd[1]: Listening on udev Control Socket.
[ 6.435013] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.438400] systemd[1]: Listening on Syslog Socket.
[ 6.444835] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.454646] systemd[1]: Listening on Journal Socket.
[ 6.468352] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 6.483823] systemd[1]: Mounting Kernel Debug File System...
[ 6.492447] systemd[1]: Created slice User and Session Slice.
[ 7.256318] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.358682] systemd-journald[114]: Received request to flush runtime journal from PID 1
[ 7.964958] mc: Linux media interface: v0.10
[ 7.968477] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.971178] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 7.971204] [vc_sm_connected_init]: start
[ 7.975310] [vc_sm_connected_init]: installed successfully
[ 8.016848] videodev: Linux video capture interface: v2.00
[ 8.073236] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.073299] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.075181] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.089028] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.104360] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.107051] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.107532] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.108028] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.108444] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.108495] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.108563] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.108604] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.108646] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.108912] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.142073] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.168647] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.171100] bcm2835_audio bcm2835_audio: there is not valid maps for state default
[ 8.364904] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.465595] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.538396] brcmfmac: F1 signature read @0x18000000=0x1542a9a6
[ 8.554180] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43436-sdio for chip BCM43430/2
[ 8.555803] usbcore: registered new interface driver brcmfmac
[ 8.741934] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43436-sdio for chip BCM43430/2
[ 8.742089] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43436-sdio for chip BCM43430/2
[ 8.747221] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.747294] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.765146] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/2 wl0: Oct 9 2020 14:44:32 version 9.88.4.65 (test) (f149b32@shgit) (r679549) FWID 01-f40f3270
[ 8.778048] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.778103] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.785799] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.785870] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.812856] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 8.812910] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 11.164458] random: crng init done
[ 11.164487] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.380484] uart-pl011 3f201000.serial: no DMA platform data
[ 11.513818] 8021q: 802.1Q VLAN Support v1.8
[ 11.911822] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 12.024211] Adding 102396k swap on /var/swap. Priority:-2 extents:4 across:223648k SSFS
[ 13.491812] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 14.963902] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 17.852732] Bluetooth: Core ver 2.22
[ 17.852865] NET: Registered protocol family 31
[ 17.852878] Bluetooth: HCI device and connection manager initialized
[ 17.852910] Bluetooth: HCI socket layer initialized
[ 17.852931] Bluetooth: L2CAP socket layer initialized
[ 17.852965] Bluetooth: SCO socket layer initialized
[ 17.872216] Bluetooth: HCI UART driver ver 2.3
[ 17.872244] Bluetooth: HCI UART protocol H4 registered
[ 17.872366] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 17.872667] Bluetooth: HCI UART protocol Broadcom registered
[ 18.193892] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.193916] Bluetooth: BNEP filters: protocol multicast
[ 18.193953] Bluetooth: BNEP socket layer initialized
