Octoprint is on the newest version, but something keeps killing it at startup.
Please advice
### What is the problem?
Octoprint shuts down 10-15 sec after startup
Apears to Phyton is running at startup, but shutdown after 10-15sec.
### What did you already try to solve it?
(SSH) Updated Linux
(SSH) Restarting Phyton service works, but it shuts down af 10-15sec.
Unable to run Octoprint in safemode ("octoprint: command not found")
### Have you tried running in safe mode
See above
### Did running in safe mode solve the problem?
N/A
Logfile:
pi@OctoPi:~/.octoprint/logs $ cat octoprint.log
2024-06-23 19:36:04,964 - octoprint.startup - INFO - ******************************************************************************
2024-06-23 19:36:04,970 - octoprint.startup - INFO - Starting OctoPrint 1.10.1
2024-06-23 19:36:04,975 - octoprint.startup - INFO - ******************************************************************************
2024-06-23 19:36:06,909 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2024-06-23 19:36:06,936 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2024-06-23 19:36:06,937 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2024-06-23 19:36:06,937 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2024-06-23 19:36:07,357 - octoprint.startup - INFO - Blacklist processing done, adding 3 blacklisted plugin versions: roomtemp (any), GcodeEditor (>=0.1.1,<=0.2.8), gcodeleveling (>=0.1.0,<=0.1.1)
2024-06-23 19:36:07,401 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2024-06-23 19:36:39,439 - octoprint.plugin.core - INFO - Plugin Anonymous Usage Tracking is disabled.
2024-06-23 19:36:42,703 - octoprint.plugin.core - INFO - Plugin Tempsgraph Plugin (0.3.7) is disabled.
2024-06-23 19:42:26,725 - octoprint.startup - INFO - ******************************************************************************
2024-06-23 19:42:26,728 - octoprint.startup - INFO - Starting OctoPrint 1.10.1
2024-06-23 19:42:26,730 - octoprint.startup - INFO - ******************************************************************************
2024-06-23 19:42:27,881 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2024-06-23 19:42:27,915 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2024-06-23 19:42:27,916 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2024-06-23 19:42:27,916 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2024-06-23 19:42:27,957 - octoprint.startup - INFO - Blacklist processing done, adding 3 blacklisted plugin versions: roomtemp (any), GcodeEditor (>=0.1.1,<=0.2.8), gcodeleveling (>=0.1.0,<=0.1.1)
2024-06-23 19:42:27,998 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2024-06-23 19:42:35,261 - octoprint.plugin.core - INFO - Plugin Anonymous Usage Tracking is disabled.
2024-06-23 19:42:35,725 - octoprint.plugin.core - INFO - Plugin Tempsgraph Plugin (0.3.7) is disabled.
