PrusaSlicer
If I generate GCODE from PrusaSlicer and upload it to Octoprint, will Octoprint add its start GCODE like it does when I send a print job directly from Cura? Or do I need to copy my Octoprint Start GCODE in to PrusaSlicer, generate GCODE and then upload to Octoprint?
OctoPrint will execute it's own GCode scripts regardless.
Thanks. Just getting ready to test with XYZ Calibration Cube
And just to provide a little more info. OP will run its GCode first. Then whatever you had in Cura would run since that is embedded the GCode file.
