Hi @NicoF!
There a some warnings and errors. I found these in your log file (and there are more):
2019-08-15 18:30:03,774 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
(multiple times)
2019-08-16 10:05:53,158 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Printer is not ready
| Last lines in terminal:
| Recv: ok T:0
| Send: M105
| Recv: ok T:0
| Send: M105
| Recv: ok T:0
| Send: M105
| Recv: ok T:0
| Send: M105
| Recv: ok T:0
| Send: M105
| Recv: ok T:0
| Send: M105
| Recv: ok T:0
| Send: M105
| Recv: ok T:0
| Send: G28
| Recv: // Printer is not ready
| Recv: // The klippy host software is attempting to connect. Please
| Recv: // retry in a few moments.
| Recv: !! Printer is not ready
(multiple times)
2019-08-15 18:29:45,094 - octoprint.environment - ERROR - Unexpected error while detecting environment
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/environment.py", line 51, in run_detection
plugin_result = self._detect_from_plugins()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/environment.py", line 128, in _detect_from_plugins
"environment data from plugin {}".format(implementation._identifier),
AttributeError: 'PiSupportPlugin' object has no attribute '_identifier'
2019-08-15 18:29:45,098 - octoprint.environment - ERROR - Error logging detected environment
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/environment.py", line 142, in log_detected_environment
_log(self._format())
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/environment.py", line 157, in _format
return u"Detected environment is Python {} under {} ({}). Details:\n{}".format(environment["python"]["version"],
KeyError: 'python'
2019-08-15 18:30:29,385 - octoprint.plugins.astroprint - ERROR - Error getting camera status: HTTPConnectionPool(host='127.0.0.1', port=8080): Max retries exceeded with url: /?action=snapshot (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x68f79690>: Failed to establish a new connection: [Errno 111] Connection refused',))
2019-08-15 19:42:47,910 - octoprint.plugins.astroprint - INFO - There was an error loading /home/pi/.octoprint/data/astroprint/print_files.yaml:
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_astroprint/AstroprintDB.py", line 49, in getPrintFiles
with open(self.infoPrintFiles, "r") as f:
IOError: [Errno 2] No such file or directory: '/home/pi/.octoprint/data/astroprint/print_files.yaml'
2019-08-16 08:39:48,801 - octoprint - ERROR - Exception on /plugin/astroprint/initialstate [GET]
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1817, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1477, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1381, in handle_user_exception
reraise(exc_type, exc_value, tb)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1475, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/app.py", line 1461, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask_principal.py", line 199, in _decorated
rv = f(*args, **kw)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_astroprint/__init__.py", line 422, in initialstate
"connected" : True if self.cameraManager.cameraActive else False,
AttributeError: 'NoneType' object has no attribute 'cameraActive'
2019-08-16 09:50:31,155 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2739, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4844, in readline
c = self.read(1)
File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
So, you need a more powerful power supply.
Check your Klipper installation.
Disable the astroprint plugin.
