My printer stops printing mid print. Octoprint will not respond Connection times out
Replaced power cable, replaced usb cable, re -installed octoprint
OctoPrint Version 1.3.10
OctoPi Version 0.15.1
Stock CR-10S Firmware
I didnt have serial logging enabled at first. This came from the terminal.
Recv: ok
Send: M27
Send: M27
Send: M27
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Send: M27
No response from printer after 11 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Changing monitoring state from "Printing" to "Offline (Error: Too many consecutive
I started another print and started serial logging, and deleted the old logs to try and get only the failed print. I'll update once it updates the logs.
This print hasn't failed yet. I have changed nothing except deleting the old log files. I have previously tried this print 4 times and it has failed in what seems to be random locations.
well wouldn't you know it....the moment i brag on it, it fails...
I've tried the cable that was supplied with the printer, and I made a trip to Best buy to grab another cable to try. Both have the same issue. I have a gold plated ferrite core cable coming. Both are about 3' in length. I haven't looked into updating firmware yet. I've been worried about bricking my control box...even though it's probably easier than I'm thinking.
