Octoprint stops mid print
Hello. The problem I face is that octoprint will stop mid print. The print head stays frozen in the same place and also I can't stop the print job from the printer. In order to unfreeze the printer I need to reconnect to it with octoprint and start printing something and then stop it. The problem is intermittent. The same job can be printed without a problem and if I try again it might not. Also the problem can occcur after just few minutes or after hours. I would like to mention that up until a week ago everything was working properly. I haven't changed anything on my setup. Thanks in advance for your help.
I changed the sd card. Checked the power supply. I tried a different usb cable. Did a clean install and restored to a backup that I know was working properly. Then tried clean install without restore and only the printer setting. The issue remains. I can print from the sd card without an issue.
Yes
NO
Version 1.7.2, Version 0.18.0, running on Raspberry Pi 3 Model B Rev 1.2, webcam logitech c270, octoprint-systeminfo-20211204173502.zip (18.9 KB)
octoprint.log (362.7 KB)
serial.log (416 KB)
Ender 3 V2, Marlin-JyersUI (Aug 10 2021 17:20:38), chrome, windows 10
