NMe
April 19, 2022, 3:33pm
21
After I wrote my previous message I turned on the printer and connected it to Octoprint and left that running for 24 hours. Before I changed the resolution on the camera that would have disconnected at some random point, but it kept its connection. After those 24 hours I intentionally started a longer print to see if the connection with the printer would stay stable and it seems like it is. Currently it has been printing for almost 72 hours and the print will finish in another couple of hours. The printer has been connected to the Pi successfully for about 100 hours now, so I guess it's safe to say it was the serial connection being overloaded with a 1280x960@10fps stream in addition to whatever amount of data Octoprint has to send/receive to/from the printer.
So while the print is not done and it's still only one print I guess this solves my issue. I'm kind of shocked that a Pi (and not even the Pi 4 apparently) is able to handle a simple webcam stream in addition to the obviously required serial communication for printing.
Would I have seen similar results if instead of the resolution I had cut the frame rate? I like making timelapses 1 FPS would be fine for that. Would that cause a 90% reduction in serial data transfered? Or is that just something that would be handled in software and still have just as much data transmitted?
The answer is unfortunately not a simple one - more 'it depends'.
For example, on my camera (Logitech C270) there are these formats available:
pi@octopi:~ $ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.200s (5.000 fps)
Interval: Discrete 0.133s (7.500 fps)
[1]: 'MJPG' (Motion-JPEG, compressed)
So the lowest I can go natively is 5fps. After that, I think (though cannot be sure as I have never properly looked at or tested it) that mjpg streamer would drop the frames in software.
rcw88
July 8, 2022, 2:36pm
23
Sorry for the late response, EMI could be a problem, but brown-outs definitely ARE. I had no end of problems with failed prints across multiple printers [all Creality] at random times. I have an ex server class UPS tucked under the print bench - a big APC, I could use the nut plugin to suspend prints in the event of a mains failure. But the big plus for the UPS is that it squashes the spikes and smooths over short supply outages.
For all the Meanwell PSU reputation, an Ender3-Pro was the worst culprit, my Pi's are powered off a DC-DC buck convertor via the printer power supply. But the problem HAS gone away. For about Β£100 APC do a small desktop UPS that's plenty big enough to keep two Ender-3's running for a short while.
Maybe worth considering, there's another post which mentions noise.
https://community.octoprint.org/t/octoprint-kept-disconnecting-from-usb-serial-and-i-think-i-found-the-culprit-rf-interferences-from-vr-headsets/45222
system
Closed
October 6, 2022, 2:37pm
24
