Hello.
I'm using :
- an up-to-date OctoPrint (on a PINE64 board) and USB connected to a CR-10S
- the tasmotta plugin with a SonOff S20 socket (the socket has the 192.168.8.61 IP)
Manually turning on/off the printer through the tasmotta plugin works fine.
My problem is that : the printer is NOT automatically shutdown when the print is done.
OctoPrint is currently sending the "web notification" about the printer about to be shutdown ... but nothing happens.
Again, if i manually click the "power" button in the top bar (green flash), it works fine and the SonOff S20 socket is powered off - that seems to validate that my SonOff socket + Tasmotta plugin are correctly configured.
I have no idea where the problem may be ...
Here are some screenshots :
Shutdown printer option : seems OK
Shutdown "web notification" (red notification in the top right corner) appears correctly : seems that OctoPrint is correctly taking that event in consideration.
Tasmotta configuration : seems OK as the manual on/off are working
Shutdown configuration : ??? (i've tryed with the " 1" for the index in the parameter, but it doesn't help)
Any idea ? I have read several things but haven't been able to find any clear informations about what my problem may be...
