I am using the latest version of Octoprint (1.3.9) on my Ultimaker 2 with Tinkergnome Firmware 17.10.01 Whatever I do, octoprint starts printing immediately. No nozzle heating, no bed heating.
If I use a finished sliced GCode file cut by S3D, or the Octoprint CuraEngine, imported Cura 15.04.5 profile, - Octoprint ignore the heating process completely.
Here are the start codes - any ideas?!?? By the way, the Octoprint Gcode scripts are all empty. Printing via SD Card without using Octoprint, everthing works fine.
Cura Setting Start Code
M190 S68
M104 S222
M109 S222
M82 ;absolute extrusion mode
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 F12000 X5 Y10 ; Cura HEATUP_POSITION_COMMAND (edited)
G1 F2400 Z30 ; bring plate to Cura PRIMING_HEIGTH (edited) with Cura HOMING_FEEDRATE
G1 Z25.0 F9000 ;move the platform down 15mm
G92 E0 ;zero the extruded lengthG1 F500 E20 ; undo end of print/abort retraction
G92 E0 ; zero the extruded length
G1 F50 E6 ; additional priming
G1 F2400 X5 Y50 Z0.3 ; wipe start position
G1 F225 Y65 E1 ; move 15mm and extrude
G1 F2100 Y80 E1 ; move 15mm
M42 S100 ; LED 40% ON
M117 Printing...
Gcode of a file sliced with S3D
G90
M82
M106 S0
M140 S75
M190 S75
M104 S240 T0
M109 S240 T0
G28 ; home all axes
G1 F6000 Z5 X5 Y10 ; Cura HEATUP_POSITION_COMMAND (edited)
G1 F500 E30 ; undo end of print/abort retraction
G1 F2400 X5 Y50 Z0.2 ; wipe start position
G1 F225 Y65 E15 ; move 15mm and extrude
G1 F2100 Y80 E20 ; move 15mm
- the reason for all my problems is Octolaps.
