What is the problem? Octoprint worked fine last night, did an update that popped up, now there's no network settings file. Unsure what else may have screwed
What did you already try to solve it? What can I do??
Logs (syslog, dmesg, ... no logs, no support) Looks like any logs are gone too?
Additional information about your network (Hardware you are trying to connect to, hardware you are trying to connect from, router, access point, used operating systems, ...)Tell me what you need and I'll add it. This is a Raspberry Pi 4 basic, 2gb ram connecting to an Ender 3 pro. Again, no problems until it popped up with an update request.
NEITHER FILE EXISTS. AS I STATED, THE NETWORK FILE, ANY LOG FILES, AND UNKNOWN OTHER FILES ARE ALL GONE. F**k it, I'm just going to wipe the install and start fresh.
Treating someone like an idiot isn't the best way to endear yourself to someone who's new to something. I stated in the ORIGINAL post that the logs were gone. If someone else can't be bothered to read what the issue is, then why are they 'trying to help' in the first place?
Well, it sure seemed like field there was viewing me as such. Maybe there should be a forum rule to actually read the OP of a thread before replying? Besides that, how many Octoprint forums are out there? Not many, I'm sure.
So do you want to get help, or do you want to continue to alienate the people who want to help you?
Your outburst up there was entirely uncalled for (and as far as I know @fieldOfView, of you'd just reminded him in a friendly tone that you already started that the logs seem to be gone, he'd apologized for the misunderstanding - but not after THAT). Further passive aggressiveness doesn't make for the best impression either, and considering the limited amount of options you have in terms of OctoPrint forums, maybe you should try to cooperate now that we have the initial misunderstanding cleared up and work towards figuring out what went wrong instead of throwing mud?
If however you insist on continuing to berate some of the most helpful community members instead, then you may leave - this isn't the place for that.
