Octoprint upgrade to latest version, nothing work's
I was using octoprint with my Tronxy x5SA pro and was being prompted to upgrade the application, so I did. Then rebooted.
Initially the web page for octoprint appeared. but would not connect to the printer. Also the camera went dead no power from the USB port to the webcam. - I have to add this was all working prior to the upgrade.
I deleted the contents of the flash drive then re-installed octoprint. Same result as above. Tried the build in another raspberry-pi W2 same result. Tried to access SSH using pi@octopi.local does not accept default R-PI id and password. Cannot directly SSH as for some reason IP has changed to IPV6
Same result
octoprint-systeminfo-20240707144159.zip (30.1 KB)
OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... as much data as possibleOctoprint version 1.10.2
octopi: Build 2023.10.09.154319 with "camera-streamer", based on OctoPi 1.0.0, running on Raspberry Pi Zero 2 W Rev 1.0
printer Tronxy x5sa pro , Firmware V1.4.1ZE_RC27m4, browser Google/Edge,OS Win10
