Yes, Thank you.
I am aware that the firmware gives the wrong response, in fact the firmware doesn't support M115 at all.
That given, how do I stop Octoprint from sending the M115 Command or Ignore the response?
The M115 command was added to smoothieware in January 2018 (see the aforementioned issue), so I would suggest updating your firmware.
Also, disabling warning doesn't seem like a good idea as you could end up ignoring a warning from your printer that there's a malfunction, such as a heater keeping heating although you've reached desired temperature, and then becoming a fire hazard.
Thank you all for your help.
I have the problem figured out.
Turns out, smoothieware has two versions.
2017, which supports the MKS-Sbase with the graphic smart controller but does not support the M115 command, and...
2020, which does NOT support the MKS-Sbase with the graphic smart controller but does support the M115 command.
According to other sources, this was intentional.
Given I have the MKS-Sbase, and Given smoothieware has build in thermal runaway protection, I have to go with the former.
At least now I know what is going on!
Also, the command M21 is unknown. This isn't an issue because it "Initialize SD Card" which is unnecessary.
