OctoPrint Web Page Becomes Unresponsive
The OctoPrint web page becomes unresponsive after a few minutes. Temperatures, terminal, and the camera feed stop updating. Refreshing the web page or reloading the link will allow the page to update again for a few minutes. I think this behavior started in version 1.9.0 and persists in version 1.9.1. Sometimes taking an action (like setting a temperature) works on the printer, but does not show on the web page. Some commands (like restart) appear to work as expected.
octoprint-systeminfo-20230716222102.zip (881.2 KB)
Refresh the browser web page, restart the Raspberry Pi.
Yes.
No.
OctoPrint version 1.9.1, OctoPi version 0.18, Creality Ender 3 (heavily modified) with BigTreeTech SKR Mini E3 V3.0, Klipper firmware, Safari browser version 16.5.1, macOS Ventura 13.4.1
Hello @pigaro !
You may update the webcam settings:
2023-07-14 00:25:51,279 - octoprint.settings - WARNING - DeprecationWarning: Detected access to deprecated settings path ['webcam', 'snapshot'], returned value is derived from compatibility overlay. Please use the webcam system introduced with 1.9.0, this compatibility layer will be removed in a future release.
The octoprint.log is quite full with this.
There is also this:
2023-07-14 07:36:02,967 - octoprint.util.comm - ERROR - Error while processing hook dashboard for phase sending:
  File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 4754, in _process_command_phase
    tags=tags,
  File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/__init__.py", line 1686, in wrapper
    return f(*args, **kwargs)
  File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_dashboard/__init__.py", line 799, in process_gcode
    current_layer_progress = int((self.layer_moves / self.layer_move_array[self.current_layer]) * 100)
IndexError: list index out of range
A problem with Dashboard. But could be a result of the first one.
This is a deprecation warning for plugin developers that are using the old webcam system rather than the new one in 1.9.0+. There's unfortunately nothing a user can do about these warnings, it's plugins that need updating for the new API. It should still work OK for the moment.
