Octoprint Web UI Infertace - Icons misaligned after update to 1.4.2 on Google Chrome
Right after update to 1.4.2 My Web UI seems to be a messy, icons are not aligned, some icons are super big and do not follow the correct pattern.
1)I have used at least 5 different laptops, all I have the same problem on Google Chrome.
2) Tried to cleaning up cache, cookies and browsing history
3) Fresh install for google chrome, same issue.
Using firefox, I can not see the same issue, everything goes fine.
Complete Logs
Would you be able to take a look at the error console, it's unlikely since everything's there but may provide insight.
Have you restarted OctoPrint? Just a thought as it does some server side caching which may be interfering with the clearing of browser cache.
You also may try safe mode.
I have the same problem.
Fisrt time OctoPrint user. Using version 1.4.2 on windows PC (server).
Browsing from Chrome got the same problem (right)
Browsing from Internet Explorer no problem (left)
See file command buttons and temperature area as some examples.
Hello @theone!
I like to point at @Charlie_Powell's post:
... and also I like you to try safemode.
Did a new clean install on RaspberryPi
Updated to 1.4.2 (was also a problem before the upgrade)
still having the same problem
Chrome console output on F5 (refresh) web page
log file
octoprint.log (21.5 KB)
Tried SAFEMODE same bad result
opened in EDGE browse and it look fine as it should
Solved
It was Aliexpress Assitant extension.
It did the inject.js.
I disabled all extensions and turned them on 1-by-1 until I found the culprit.
That's an OctoPrint plugin?
Probably a chrome plugin, that was doing creating something annoying & conflicting in the Bootstrap styling.
Yes Chrome plugin
