Octoprint WEBUI not starting after reboot.
Created new SD images on other SD cards several times. 1st run works fine.
Image: 2019-09-26-octopi-buster-lite-0.17.0.img
Logs
pi@octopi:~ $ cat ~/.octoprint/logs/octoprint.log
2020-06-04 06:38:28,569 - octoprint.startup - INFO - ******************************************************************************
2020-06-04 06:38:28,570 - octoprint.startup - INFO - Starting OctoPrint 1.3.12
2020-06-04 06:38:28,571 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2020-06-04 06:38:28,572 - octoprint.startup - INFO - Reason for safe mode: problem during last startup
2020-06-04 06:38:28,572 - octoprint.startup - INFO - ******************************************************************************
2020-06-04 06:38:28,869 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-06-04 06:38:28,871 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2020-06-04 06:38:28,902 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-06-04 06:38:29,581 - octoprint.plugin.core - INFO - Found 16 plugin(s) providing 15 mixin implementations, 23 hook handlers
2020-06-04 06:38:29,628 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-06-04 06:38:29,641 - octoprint.server - INFO - Intermediary server started
2020-06-04 06:38:29,642 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-06-04 06:38:29,706 - octoprint.plugin.core - INFO - Found 16 plugin(s) providing 15 mixin implementations, 23 hook handlers
2020-06-04 06:38:29,723 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-06-04 06:38:29,723 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-06-04 06:38:29,752 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-06-04 06:38:30,312 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-06-04 06:38:30,877 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-06-04 06:38:30,878 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-06-04 06:38:30,879 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-06-04 06:38:30,882 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2020-06-04 06:38:30,890 - octoprint.plugin.core - INFO - 16 plugin(s) registered with the system:
| !Themeify (1.2.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2020-06-04 06:38:30,900 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 1904005120
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.1
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-06-04 06:38:30,905 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-06-04 06:38:30,906 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-06-04 06:38:31,304 - octoprint.server - INFO - Shutting down intermediary server...
2020-06-04 06:38:31,645 - octoprint.server - INFO - Intermediary server shut down
2020-06-04 06:38:31,646 - octoprint.events - INFO - Processing startup event, this is our first event
2020-06-04 06:38:31,647 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2020-06-04 06:38:31,649 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-06-04 06:38:31,654 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-06-04 06:38:31,655 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-06-04 06:38:31,673 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-06-04 06:38:31,673 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-06-04 06:38:31,682 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Creality"' for _http._tcp
2020-06-04 06:38:31,690 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Creality"' for _octoprint._tcp
2020-06-04 06:38:31,749 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "Creality" for SSDP
2020-06-04 06:38:32,101 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
pi@octopi:~ $ ps -ef | grep -i octoprint | grep -i python
pi 1563 1 0 06:38 ? 00:00:05 /home/pi/oprint/bin/python2 /home/pi/oprint/bin/octoprint serve --host=127.0.0.1 --port=5000
pi@octopi:~ $ sudo service octoprint status
β octoprint.service - LSB: OctoPrint daemon
Loaded: loaded (/etc/init.d/octoprint; generated)
Active: active (running) since Thu 2020-06-04 06:38:27 BST; 4min 12s ago
Docs: man:systemd-sysv-generator(8)
Process: 1557 ExecStart=/etc/init.d/octoprint start (code=exited, status=0/SUCCESS)
Tasks: 31 (limit: 3738)
CGroup: /system.slice/octoprint.service
ββ 531 /usr/bin/vcgencmd get_throttled
ββ 828 /usr/bin/vcgencmd get_throttled
ββ 985 /usr/bin/vcgencmd get_throttled
ββ1111 /usr/bin/vcgencmd get_throttled
ββ1227 /usr/bin/vcgencmd get_throttled
ββ1362 /usr/bin/vcgencmd get_throttled
ββ1538 /usr/bin/vcgencmd get_throttled
ββ1563 /home/pi/oprint/bin/python2 /home/pi/oprint/bin/octoprint serve --host=127.0.0.1 --port=5000
ββ1597 /usr/bin/vcgencmd get_throttled
Jun 04 06:38:27 octopi systemd[1]: octoprint.service: Found left-over process 1538 (vcgencmd) in control group while starting unit. Ignoring.
Jun 04 06:38:27 octopi systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Jun 04 06:38:27 octopi systemd[1]: Starting LSB: OctoPrint daemon...
Jun 04 06:38:27 octopi octoprint[1557]: Starting OctoPrint Daemon: OctoPrint.
Jun 04 06:38:27 octopi systemd[1]: Started LSB: OctoPrint daemon.
WebcamUI also not starting:
