Octoprint will not connect to Ender 3 V2 Fresh Install
I just installed Octoprint on a fresh install of Debian 11 and have tried everything, however it will not see my Ender 3 V 2. The computer will see it, however OctoPrint will not. I have tested the printer on another Octoprint install and it does work fine so I am unsure what I am doing wrong. Do I need to expose ports some how? Below is a log file.
2023-01-27 02:15:01,357 - Enabling serial logging
2023-01-27 02:15:07,421 - Changing monitoring state from "Offline" to "Detecting serial connection"
2023-01-27 02:15:07,435 - Performing autodetection with 10 port/baudrate candidates: /dev/ttyUSB0@250000, /dev/ttyUSB0@115200, /dev/ttyS3@250000, /dev/ttyS3@115200, /dev/ttyS2@250000, /dev/ttyS2@115200, /dev/ttyS1@250000, /dev/ttyS1@115200, /dev/ttyS0@250000, /dev/ttyS0@115200
2023-01-27 02:15:07,435 - Trying port /dev/ttyUSB0, baudrate 250000
2023-01-27 02:15:07,439 - Connecting to port /dev/ttyUSB0, baudrate 250000
2023-01-27 02:15:07,440 - Could not open port /dev/ttyUSB0, baudrate 250000, skipping
2023-01-27 02:15:07,440 - Trying port /dev/ttyUSB0, baudrate 115200
2023-01-27 02:15:07,445 - Connecting to port /dev/ttyUSB0, baudrate 115200
2023-01-27 02:15:07,462 - Could not open port /dev/ttyUSB0, baudrate 115200, skipping
2023-01-27 02:15:07,483 - Trying port /dev/ttyS3, baudrate 250000
2023-01-27 02:15:07,533 - Connecting to port /dev/ttyS3, baudrate 250000
2023-01-27 02:15:07,545 - Could not open port /dev/ttyS3, baudrate 250000, skipping
2023-01-27 02:15:07,545 - Trying port /dev/ttyS3, baudrate 115200
2023-01-27 02:15:07,548 - Connecting to port /dev/ttyS3, baudrate 115200
2023-01-27 02:15:07,549 - Could not open port /dev/ttyS3, baudrate 115200, skipping
2023-01-27 02:15:07,549 - Trying port /dev/ttyS2, baudrate 250000
2023-01-27 02:15:07,551 - Connecting to port /dev/ttyS2, baudrate 250000
2023-01-27 02:15:07,553 - Could not open port /dev/ttyS2, baudrate 250000, skipping
2023-01-27 02:15:07,553 - Trying port /dev/ttyS2, baudrate 115200
2023-01-27 02:15:07,563 - Connecting to port /dev/ttyS2, baudrate 115200
2023-01-27 02:15:07,568 - Could not open port /dev/ttyS2, baudrate 115200, skipping
2023-01-27 02:15:07,586 - Trying port /dev/ttyS1, baudrate 250000
2023-01-27 02:15:07,604 - Connecting to port /dev/ttyS1, baudrate 250000
2023-01-27 02:15:07,618 - Could not open port /dev/ttyS1, baudrate 250000, skipping
2023-01-27 02:15:07,618 - Trying port /dev/ttyS1, baudrate 115200
2023-01-27 02:15:07,620 - Connecting to port /dev/ttyS1, baudrate 115200
2023-01-27 02:15:07,633 - Could not open port /dev/ttyS1, baudrate 115200, skipping
2023-01-27 02:15:07,633 - Trying port /dev/ttyS0, baudrate 250000
2023-01-27 02:15:07,635 - Connecting to port /dev/ttyS0, baudrate 250000
2023-01-27 02:15:07,636 - Could not open port /dev/ttyS0, baudrate 250000, skipping
2023-01-27 02:15:07,636 - Trying port /dev/ttyS0, baudrate 115200
2023-01-27 02:15:07,638 - Connecting to port /dev/ttyS0, baudrate 115200
2023-01-27 02:15:07,655 - Could not open port /dev/ttyS0, baudrate 115200, skipping
2023-01-27 02:15:07,655 - Changing monitoring state from "Detecting serial connection" to "Error"
2023-01-27 02:15:07,656 - Changing monitoring state from "Error" to "Offline after error"
2023-01-27 02:15:11,100 - Changing monitoring state from "Offline" to "Detecting serial connection"
2023-01-27 02:15:11,112 - Performing autodetection with 5 port/baudrate candidates: /dev/ttyUSB0@250000, /dev/ttyS3@250000, /dev/ttyS2@250000, /dev/ttyS1@250000, /dev/ttyS0@250000
2023-01-27 02:15:11,112 - Trying port /dev/ttyUSB0, baudrate 250000
2023-01-27 02:15:11,114 - Connecting to port /dev/ttyUSB0, baudrate 250000
2023-01-27 02:15:11,116 - Could not open port /dev/ttyUSB0, baudrate 250000, skipping
2023-01-27 02:15:11,116 - Trying port /dev/ttyS3, baudrate 250000
2023-01-27 02:15:11,121 - Connecting to port /dev/ttyS3, baudrate 250000
2023-01-27 02:15:11,125 - Could not open port /dev/ttyS3, baudrate 250000, skipping
2023-01-27 02:15:11,127 - Trying port /dev/ttyS2, baudrate 250000
2023-01-27 02:15:11,130 - Connecting to port /dev/ttyS2, baudrate 250000
2023-01-27 02:15:11,141 - Could not open port /dev/ttyS2, baudrate 250000, skipping
2023-01-27 02:15:11,141 - Trying port /dev/ttyS1, baudrate 250000
2023-01-27 02:15:11,143 - Connecting to port /dev/ttyS1, baudrate 250000
2023-01-27 02:15:11,146 - Could not open port /dev/ttyS1, baudrate 250000, skipping
2023-01-27 02:15:11,146 - Trying port /dev/ttyS0, baudrate 250000
2023-01-27 02:15:11,148 - Connecting to port /dev/ttyS0, baudrate 250000
2023-01-27 02:15:11,150 - Could not open port /dev/ttyS0, baudrate 250000, skipping
2023-01-27 02:15:11,150 - Changing monitoring state from "Detecting serial connection" to "Error"
2023-01-27 02:15:11,152 - Changing monitoring state from "Error" to "Offline after error"
I am running the latest OctoPrint install on a FRESH Debian install, I just installed it a couple of hours ago.
plugin_pluginmanager_console.log (199.8 KB)
serial.log (7.1 KB)
octoprint.log (1.1 MB)
Please always give the actual version. 'latest' can be very different in a short time.
What guide did you use to install OctoPrint on Debian?
Thank you for your response! The latest as far as I know Version 1.8.6. I used the installation instructions for linux provided on the OctoPrint website here Setting up OctoPrint on a Raspberry Pi running Raspberry Pi OS (Debian)
Thanks again for your help!
