Octoprint will not connect wirelessly after upgrade
Cannot connect to the PI using the web interface. Was running old version of Octoprint on Pi 3 b+ without problems. Popup appeared stating that I am running an old Python and must upgrade. Did a backup and downloaded Pi imager. Followed the instructions for imager and rebooted the Octopi with new image. Now the message "Unable to connect" appears in firefox when trying to connect. The error in Microsoft edge is: ERR_CONNECTION_REFUSED. For a split second prior to showing the "Unable to connect" message, there appears a screen that typically appears when you visit an unsafe website and your options are to proceed (unsafe) or go back. But that screen instantly disappears and the "unable to connect" screen stays in its place.
I tried the image process again. I tried to turn off my firewall. I tried to connect using the local hostname and the ip address. I looked at my router settings to determine the PI's IP address. I pinged the PI and connected to the PI using putty. I changed PIs IP address to a static IP. I tried everything in the FAQ although most/all of it was not applicable because the PI is connected to the network just fine. I looked at a lot of other posts here. I think based on everything I've done, the problem lies in the invalid self-signed security certificate the author warns about. But the problem might also lie in the fact netstat reports nothing listening on port 80. One post I read mentioned a proxy program was not running and causing the problem.
I cannot connect so that limits my logs. I will supply any logs requested. Here is netstat showing nothing is listening on port 80.
pi@raspberrypi:~ netstat -tulpen (Not all processes could be identified, non-owned process info will not be shown, you would have to be root to see it all.) Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 8979 - tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 13758 - tcp6 0 0 ::1:631 :::* LISTEN 0 8978 - tcp6 0 0 :::22 :::* LISTEN 0 13760 - udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 10096 - udp 0 0 0.0.0.0:68 0.0.0.0:* 0 15529 - udp 0 0 0.0.0.0:631 0.0.0.0:* 0 14488 - udp 0 0 0.0.0.0:56959 0.0.0.0:* 108 10098 - udp6 0 0 :::5353 :::* 108 10097 - udp6 0 0 :::44294 :::* 108 10099 - pi@raspberrypi:~
I am using a Windows 10 vmware virtual machine connected to an RT-AC68R wirelessly that the Octopi is also connected to wirelessly.
Hello @med458 !
Please format code scripts with </> in the editor's menu bar.
Can you login via LAN?
BTW: What have you upgraded from?
Thank you for your reply. Sorry about the formatting. Here is the netstat
pi@raspberrypi:~ $ netstat -tulpen
pi@raspberrypi:~ $
I just connected the Octopi to LAN. Now my router device table shows it is connected wirelessly and to LAN. Unfortunately, attempting to connect to LAN failed with the same result.
It's a wild guess, but I'm going to go based on your hostname being raspberry not octopi - did you select the correct image in the Raspberry Pi imager? Of course I could be wrong - you can change it yourself manually.
Your netstat result suggests that none of the usual OctoPi processes are running.
Verify that you chose 'OctoPi' not another Raspberry Pi OS through the Pi imager. It is under 'Other Specific Purpose OS > 3D Printing > OctoPi'.
I was lazy and just went with the first choice. That must be my problem. I will follow your instructoins and get back to you. Thank you for your reply.
That was the problem. I mistakenly thought that the imager was created by the Octopi team and that blindly clicking "next" and accepting all defaults would work. Thank you very much, all is working well now, have a good weekend.
