###What is the problem?
I have a MAKERGEAR M3-ID that a pervious coworker did unknown things to. Long story short the individual no longer works here. Anyways the problem I am having with the M3 is I am getting the "Octoprint is not currently running" screen:
The OctoPrint server is currently not running
If you just started up your Raspberry Pi, please wait a couple of seconds, then try to refresh this page.
If the issue persists, please log into your Raspberry Pi via SSH and check the following:
- Verify that the process is running:
ps -ef | grep -i octoprintshould show a python process. - If it isn't, the question is why. Take a look into
~/.octoprint/logs/octoprint.log, there might be an error logged in there that helps to determine what's wrong. - You might also want to try if you can restart the server (if no obvious error is visible):
sudo service octoprint restart.
I am able to SSH into it using putty and got the log. This is my first time doing any of this so I don't exactly know what I am doing and I have googled for hours trying to figure this thing out.
I tried to factory reset the printer, using the reset button for more than 60 seconds. The printer went through the appropriate beeps etc and booted back up and connected to the wifi again. I can see it on the router connection page. If it properly reset it should have lost the wifi information etc.
I don't know how to enter safe mode.
Complete Logs
Since the log is so long I couldn't upload it here. Text limit was exceeded. Google sheet link:
Again, I have no idea what the previous person tried to do to this unit or how it got in this condition. thanks for making it this far in my post.
