I have been able to print successfully with octoprint, but for some reason if i run a print and cancel it, then try to put in commands into the terminal, my printer to not respond. If I send a G28, it doesn't home, but i can home from the lcd panel of my printer. Also, the z axis motors lock up, and the move axis buttons under the control tab don't work. However, I can still send gcode to the printer and print things, so there is some functionality.
I rebooted my machines (printer and octopi server), as well as uninstalled some plugins I thought were causing issues...When i go to run G28, it gives me this output:
Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
Also, worth noting, when it works and sends a Control command (press one of the arrow buttons), it sends it with F5, so it goes super slow. Not sure how to change this/if its related.
Additional information about your setup (OctoPrint Version 1.3.10, OctoPi Version 0.16.0, running on Raspberry Pi 3 Model B Plus Rev 1.3, CR10S S4, Marlin 1.1.9, log attached)octoprint.log (49.8 KB)
