My Problem is that Octoprint won't start. If i try to start it manually, even in safe mode. I get the follow error with the command Octoprint safemode:
pi@octopi:~ $ octoprint safemode
File "/home/pi/oprint/bin/octoprint", line 8, in <module>
sys.exit(main())
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/__init__.py", line 628, in main
from octoprint.cli import octo
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/__init__.py", line 141, in <module>
from .user import user_commands
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/user.py", line 13, in <module>
from octoprint.access.groups import FilebasedGroupManager
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/access/groups.py", line 20, in <module>
from octoprint.access.permissions import Permissions, OctoPrintPermission
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/access/permissions.py", line 9, in <module>
from flask import g, abort
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/__init__.py", line 19, in <module>
from . import json
File "/home/pi/oprint/local/lib/python2.7/site-packages/flask/json/__init__.py", line 25, in <module>
import dataclasses
File "/home/pi/oprint/local/lib/python2.7/site-packages/dataclasses.py", line 202
class InitVar(metaclass=_InitVarMeta):
SyntaxError: invalid syntax
Updated the system, pip and python as well
One other thing to mention: I've also installed another version of pip which makes it available globally, so i could use my RPi for Python Programming purposes. I reckon that there is some issue with different Pip or python versions.
Any suggestions on what i should do?
Any help is appreciated!
Cheers,
Matteo
