Can you also upload plugin_softwareupdate_console.log ?
You'll want to fix this too: !!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
I was trying to run them straight from octoprint notification. I have changed my input power and have not seen the under voltage on the end of the log anywhere.
Actually an undervolatge issue prevents updates of any kind.
2021-04-23 22:48:35,788 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 915718144
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.18.0
| throttle_state: '0x50005'
| python:
| pip: 20.3.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
