server would not start
start in safe mode
yes
no
does not work from command line
OctoPrint version : 1.8.1
OctoPi version : 0.18.0
after updating octoprint server (running on rasperry PI with Phyton 3) would not start. The command
"~/oprint/bin/octoprint systeminfo" would just end but produce no file.
Also I am sorry, but I see no button to attach any files to this post...
----cut ----
2022-06-27 21:26:17,237 - octoprint.startup - INFO - ******************************************************************************
2022-06-27 21:26:17,240 - octoprint.startup - INFO - Starting OctoPrint 1.8.1
2022-06-27 21:26:17,242 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2022-06-27 21:26:17,242 - octoprint.startup - INFO - Reason for safe mode: setting in config.yaml
2022-06-27 21:26:17,242 - octoprint.startup - INFO - ******************************************************************************
2022-06-27 21:26:17,879 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2022-06-27 21:26:17,994 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2022-06-27 21:26:17,994 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2022-06-27 21:26:17,995 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2022-06-27 21:26:18,011 - octoprint.startup - INFO - Blacklist processing done, adding 3 blacklisted plugin versions: roomtemp (any), GcodeEditor (>=0.1.1,<=0.2.8), gcodeleveling (>=0.1.0,<=0.1.1)
2022-06-27 21:26:18,031 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2022-06-27 21:26:18,608 - octoprint.plugin.core - ERROR - Error loading plugin announcements
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/core.py", line 1274, in _import_plugin
module = _load_module(module_name, spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/core.py", line 52, in _load_module
return imp.load_module(name, f, filename, details)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/vendor/imp.py", line 238, in load_module
return load_package(name, filename)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/vendor/imp.py", line 212, in load_package
return _load(spec)
File "", line 696, in _load
File "", line 677, in _load_unlocked
File "", line 728, in exec_module
File "", line 219, in _call_with_frames_removed
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements/init.py", line 22, in
from octoprint.server.util.flask import (
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/server/init.py", line 39, in
from watchdog.observers import Observer
File "/home/pi/oprint/lib/python3.7/site-packages/watchdog/observers/init.py", line 62, in
from .inotify import InotifyObserver as Observer
File "", line 983, in _find_and_load
File "", line 967, in _find_and_load_unlocked
File "", line 724, in exec_module
File "", line 857, in get_code
File "", line 525, in _compile_bytecode
ValueError: bad marshal data (unknown type code)
2022-06-27 21:26:18,648 - octoprint.plugin.core - ERROR - Error loading plugin logging
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging/init.py", line 14, in
from octoprint.server import NO_CONTENT
2022-06-27 21:26:18,685 - octoprint.plugin.core - ERROR - Error loading plugin appkeys
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys/init.py", line 12, in
from octoprint.server import NO_CONTENT, admin_permission, current_user
2022-06-27 21:26:19,034 - octoprint.plugin.core - ERROR - Error loading plugin errortracking
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking/init.py", line 64, in
from octoprint.plugins.backup import InsufficientSpace
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup/init.py", line 8, in
2022-06-27 21:26:19,194 - octoprint.plugin.core - ERROR - Error loading plugin pluginmanager
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager/init.py", line 29, in
from octoprint.server import safe_mode
2022-06-27 21:26:19,307 - octoprint.plugin.core - ERROR - Error loading plugin softwareupdate
return _load(spec)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate/init.py", line 24, in
from octoprint.server import BRANCH, NO_CONTENT, REVISION, VERSION
2022-06-27 21:26:19,478 - octoprint.plugin.core - ERROR - Error loading plugin backup
return _load(spec)
2022-06-27 21:26:20,148 - octoprint.plugin.core - INFO - Found 24 plugin(s) providing 11 mixin implementations, 19 hook handlers
2022-06-27 21:26:20,299 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/oprint/bin/octoprint", line 8, in
sys.exit(main())
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/init.py", line 936, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1130, in call
return self.main(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1055, in main
rv = self.invoke(ctx)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1657, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 1404, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/oprint/lib/python3.7/site-packages/click/core.py", line 760, in invoke
return __callback(*args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/click/decorators.py", line 26, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/cli/server.py", line 330, in serve_command
disable_color=no_color,
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/cli/server.py", line 145, in run_server
from octoprint.server import CannotStartServerException, Server
