Cr10s Pro V2 - Offset and leveling set up on printer. If I use the sd card I get near perfect prints without level or z offset issues. Once I take the Gcode to Octoprint the nozzle is either way too high or too low. This has created issues with my nozzle digging into the bed or wasting filament.
I have attempted to pause multiple prints and adjust the z offset using the controls in Octoprint. If the nozzle is too high, it will not let me go any lower using this controls. The axis stops lowering past a certain point for the z axis. (if i do this manually on the printer it works until I resume on Octoprint and then it raises again). I have had to manually adjust the offset at the rails to get anything close to a decent print when using Octoprint.
Yes, it did not solve the issue. I have minimal Plugins (Octolapse, spaghetti detective) because this is a brand new canakit setup and I didnt want to complicate anything.
Complete Logs
NO logs available - all prints have been cancelled.
OCtoprint version Version 1.4.2, Raspberry Pi 4b, Cr10s Pro V2 - stock firmware, microsoft edge, windows
I tried to do another print and the z axis just went to the top of the gantry and was trying to grind itself to infinilty. I really dont understand why this doesnt work. I have included a serial log from another print I did unsuccessfully with Octoprint. serial.log (296 Bytes)
The controls in OctoPrint move the nozzle using ordinary G0/1 commands, this has no effect on the z offset. If you use these controls while paused in the middle of a print job, the nozzle will return to its original position once the print is resumed.
To duplicate the z offset control on the printer itself, you need to use M206 commands. Also available is the M851 command. The z offset may be stored in the EEPROM so use M500 to store an updated value (see M501-M503 as well)
I don't own a Creality printer so I don't know how they implemented printing from the SD card with regards to homing, leveling, and setting the z offset. If you create a small object like a 2x2x2mm cube, slice it, print it from the SD card successfully, and then upload that gcode here, it will help us understand the issue better.
