Octroprint doesnt work after upgrading ender 3 pro with an skr mini e3 v3 mainboard
Octroprint doesnt work after upgrading ender 3 pro with a btt skr mini e3 v3 mainboard
Updated octoPi to newest version, bought another skr mini e3 v3 mainboard, Updated Octoprint to version 1.9.2, tried various cables. Tried completed new Marlin firmware for board.
Yes, didnt help
browser.user_agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 8204619776
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2023-05-01T16:37:01Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: False
octoprint.version: 1.9.2
systeminfo.generated: 2023-07-25T23:34:52Z
systeminfo.generator: zipapi
Error recieved when attempting to connect to octoprint:
Changing monitoring state from "Offline" to "Opening serial connection"
Changing monitoring state from "Opening serial connection" to "Error"
Unexpected error while connecting to serial port /dev/ttyACM0, baudrate 115200 from hook GPX: Timeout: 'Timeout' @ comm.py:_open_serial:3920
Why do you have the GPX plugin installed? It has nothing to do with your printer and will actively make things worse.
Thank you, that was the problem
