Odd issue with Timelapse
Not camera specific, camera is working fine
For a while now, several months, almost randomly my octoPrint will stop attempting to grab the still images to generate a timelapse. In the OctoPrint log, even with debugging enabled for timelapse, it doesn't appear to be attempting/concurring at all.
Enabled debugging on octoprint.timelapse to try to get an error message. Restarting Pi running OctoPrint temporarily seems to fix it
I have not, no error message in log
N/A
octoprint-systeminfo-20260104211112.zip (16.8 KB)
Pi4 running Ubuntu 24.04 with OctoPrint 1.11.5 and Python 3.12.3
My cameras run from a separate LibreCompute Le Potato running Ubuntu 22.04.4 which grabs the still images and stitches them together and posts it to an Apache Web Server running on the Le Potato for me to view in my browser and for OctoPrint to wget/curl to produce the timelapse videos. Why the separate device, I found that sometime the image capture will get frozen on the camera and not actually grab new images and I am using a script to track that on the Le Potato and reboot when it occurs. If this was on the same device, I would have to wait for the print to finish and would not have a usable timelapse, and some of my prints run for multiple days.
I think it all started when I tried to switch from a Pi4 to a Le Computer to drive the printer and many troubleshooting hours later over several weeks where long prints would just randomly fail, I determined that there must be a USB issue on the Le Potato making it incompatible with my printer and moved back to the Pi4. I also had a MicroSD card get corrupted on me but was able to extract the .octoprint directory and reinstall everything else, maintaining my settings/achievements, but since then I have just used the built in backup/restore method.
I am not sure if it is worth renaming the .octoprint and OctoPrint VENV and doing a fresh setup/install, and if I did do that, I would like to keep my achievements and achievement stats as I am currently at 25/36 (should be higher, but for some reason can't get "What Could Possibly Go Wrong?" to trigger even when I purposely caused an undervolt issue and the undervolt icon was in the top bar).
Hope y'all don't mind me cross-posting from Reddit: https://www.reddit.com/r/octoprint/comments/1q0udyj/odd_issue_with_timelapse/
Is there a way to migrate the achievements and counters to a fresh OctoPrint instance without doing a backup/restore so everything else comes in with a fresh install? It is just really strange that my only issue is it stops attempting to grab timelapse images when starting a new print seemingly at random (but often enough that it happens at least once a week).
You could just extract the achievements data folder from the backup, and then put it back on the new instance maybe. File path is /home/<username>/.octoprint/data/achievements
Actually, the restore process is doing exactly what you are potentially doing manually renaming the .octoprint folder. It renames the folder and restores stuff from the zip file you provide, fresh installs the plugins that were installed before.
Thanks, I will give that a try. I am question maybe something corrupt in my configuration, why I don't want to restart anything but stats and achievements and will just set up everything else manually
Just found something that might be a potential cause and wondering why it didn't cause more problems: unattended-upgrades
Ubuntu 24.04 appears to have gotten pretty aggressive with this even taking down some of my other systems recently upgraded from 22.04. I have disabled it on my OctoPrint Pi and will monitor to see if that resolved it before going down the rebuild route.
Circling back on this. Disabled auto-updates in Ubuntu didn't help, but starting fresh and manually coping my configs and setting over appears to have fixed it. The only thing I preserved from my old config directory was the .octoprint/data/achievements folder. I suspected my issue was some sort of hidden corruption from a failing MicroSD card and this supports that theory.
In case anyone wonders, I do have my timelapse tmp and backup folders redirected to flash drives so the daily backups and timelapse JPEGs don't add additional wear to the MicroSD and only application data/logs, uploads, and finished renders live on the MicroSD.
