Hi there,
I cannot connect to my Prusa i3 MK3S with MMU2S from the Raspberry zero W connected to the Einsy board. I get the error message:
Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2739).
I have contact the Prusa helpline and I controlled the soldering on the pi, the settings on the i3, disconnect the MMU2S, adding the serial port: /dev/ttyAMA0, downgrade to firmware, change the baud rate manually to 115200 from AUTO, factory reset and reflash the firmware back to 3.7.0,
*OctoPrint 1.3.11 running on OctoPi 0.16.0,
Prosa i3 MK3S MMU2S firmware 3.7.1-2266
serial log:
*2019-05-16 18:39:24,759 - Enabling serial logging*
*2019-05-16 18:40:21,394 - Connecting to: /dev/ttyAMA0*
*2019-05-16 18:40:21,407 - Changing monitoring state from "Offline" to "Opening serial port"*
*2019-05-16 18:40:21,450 - Connected to: Serial<id=0xafd89f70, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor*
*2019-05-16 18:40:21,461 - Changing monitoring state from "Opening serial port" to "Connecting"*
*2019-05-16 18:40:21,533 - Unexpected error while reading serial port, please consult octoprint.log for details: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2739*
*2019-05-16 18:40:21,546 - Send: N0 M110 N0*125*
*2019-05-16 18:40:21,566 - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2739)"*
*2019-05-16 18:40:21,593 - Connection closed, closing down monitor*
octoprint log:
*2019-05-16 18:18:47,339 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"*
*2019-05-16 18:18:47,386 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"*
*2019-05-16 18:18:47,421 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0*
*2019-05-16 18:18:47,429 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port*
*Traceback (most recent call last):*
* File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2739, in _readline*
* ret = self._serial.readline()*
* File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4828, in readline*
* data += bytearray(self.read(self.in_waiting))*
* File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 467, in in_waiting*
* s = fcntl.ioctl(self.fd, TIOCINQ, TIOCM_zero_str)*
*IOError: [Errno 25] Inappropriate ioctl for device*
*2019-05-16 18:18:47,463 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline (Error: IOError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:2739)"*
*2019-05-16 18:29:46,815 - octoprint.server.heartbeat - INFO - Server heartbeat <3*
*2019-05-16 18:34:48,890 - tornado.access - WARNING - 404 GET /dryrun-activated (::ffff:192.168.178.57) 74.97ms*
I have no idea, please can anyone help me?
Many thanks in advance,
John
