Canyon CNR-WCAM43
(Microdia PC Camera (SN9C325 + OM6802)
Octoprint does not recognize it.
v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'JPEG' (JFIF JPEG, compressed)
sudo nano /var/log/webcamd.log
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
config file='/boot/octopi.txt':USB device was not set in options, starting MJPG-streamer with the first found video device: /dev/video0
<13>Dec 30 09:54:53 root: Starting USB webcam
 Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -y -d /dev/video0
 MJPG Streamer Version.: 2.0
 i: Frames Per Second.: 10
 i: Format............: YUYV
 i: JPEG Quality......: 80
 i: Could not obtain the requested pixelformat: YUYV , driver gave us: RGB3
 ... will try to handle this by checking against supported formats.
 ... Falling back to RGB24 mode (consider using -fourcc RGB24 option). Note that this requires much more CPU power
 Setting FPS on the capture device is not supported, fallback to software framedropping
 : Invalid argument
 i: Frame period time ......: 100 ms
 Unable to map buffer: Invalid argument
 i: init_VideoIn failed
 Done bringing up all configured video devices
 Scanning again in two minutes
Yes
I am using a Raspberry Pi Zero 2 W.
I can use the webcam without problems with Elementary OS.
