Old POLAR3D Printer
So my school recently gave up an old POLAR3D printer that I am trying to use with Octoprint. I switched out the raspberry pi in it to a pi4 and installed octoprint. In the Octoprint interface, I can control all axes fine, but I can't extrude for some reason. Even with a file sliced from Cura the printer will move but won't extrude. Any ideas?
What did you do to try and solve it?
Research
Yes
octoprint-systeminfo-20230212171607.zip (21.0 KB)
Octoprint version: 1.8.6
Firmware: 2021.10.11
Browser: Edge
Printer: POLAR3D
Motors are controlled by Printrbot F5
Hi :tentacle:
Please enable the serial.log (click on the link for help)
It tells us what happened and how the printer responded to the extrude commands.
Just test the usual things - move the axis, heat it up, extrude - and upload a new systeminfo bundle
octoprint-systeminfo-20230214213339.zip (11.0 KB)
octoprint-logs.zip (21.2 KB)
Moved in all directions, Homed Axises, Heated to 100C, extruded and retracted 5mm
You have to enable the serial.log first, it is not captured automatically and your log is empty.
