What are the current slicing options for octoprint? I am super disappointed that someone decided to remove the cura 15 support. I mean, I get it. I even do not disagree with the logic behind it. But on-server slicing is basically the primary reason I use octoprint. I use an actual alternative OS, not simply another linux distro, and there are basically zero working slicers (which is kind of ridiculous considering freecad runs great, do cura devs go out of their way to make their code nonportable or what)
So here I am clinging to an older octoprint that still has cura 15 (preinstalled plugin?). Is the plugin going to continue to be supported, or what are the other options now that octoprint is moving away from native slicing
