One of the octoprint services (no out of 4) crashes randomly
My printserver has 4 instances (I know it is not officially supported, or did it change??)
service octoprint2 randomly (at least once a day) becomes unavailable so I had to restart it manually
sudo service octoprint2 restart
This just did happen over night seems in the time period not being used.
But now a bigger print failed in the middle of it Printer just stopped
So the question is what happens has it to do with the serviece failed and therefore why does the service stopp and have I fix for it.
Have extracted the section out of 2 restarts of the octoprin2 service inbetween the print fail happend and will attache
Print Failed octoprint2 service keeps crashing from time to time.zip (12.0 KB)
Not jet but right now I will start a print on save mode. and will than let it rest over night in the safe mode if the print does not fail
To be investigated
yes attached
octoprint-systeminfo-20230504100240.zip (89.3 KB)
1.8.7 0,17,0 rapberry pi 4 instances
It appears, that the Matrix Notifier has some trouble executing:
2023-05-03 11:38:30,553 - octoprint.plugin - ERROR - Error while calling plugin matrix_notifier
  File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/plugin/__init__.py", line 273, in call_plugin
  File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/__init__.py", line 1688, in wrapper
    return f(*args, **kwargs)
  File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_matrix_notifier/plugin.py", line 109, in on_after_startup
    user_id = self.client.whoami()["user_id"]
  File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_matrix_notifier/matrix.py", line 69, in whoami
    return self._send(method, path)
  File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_matrix_notifier/matrix.py", line 44, in _send
    resp = urlopen(req)
  File "/usr/lib/python3.7/urllib/request.py", line 222, in urlopen
    return opener.open(url, data, timeout)
  File "/usr/lib/python3.7/urllib/request.py", line 531, in open
    response = meth(req, response)
  File "/usr/lib/python3.7/urllib/request.py", line 641, in http_response
    'http', request, response, code, msg, hdrs)
  File "/usr/lib/python3.7/urllib/request.py", line 569, in error
    return self._call_chain(*args)
  File "/usr/lib/python3.7/urllib/request.py", line 503, in _call_chain
    result = func(*args)
  File "/usr/lib/python3.7/urllib/request.py", line 649, in http_error_default
    raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 401: Unauthorized
BTW:
  • The OctoPi version is a bit out of date.
  • There are some Plugins marked as incompatible:
 | *SlicerSettingsTab (1.0.3) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_SlicerSettingsTab
 | *Yamlpatcher (0.1.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_yamlpatcher
I do not know what the matrix notifier does and from which plugin it comes
Can it be uninstalled or is it system internal.
thanks for the other plugins will try to uninstall and reinstall
since now I tried to get arround because the custamisationlevel is high and it would take a lot of time to setup everything from scratch
For the matrix Notifier:
Yamlpatcher won't work with Python 3
