Resbperry pi has connection, octoprint gives No more candidates to test, and no working port/baudrate combination detected i have tried thru the ip adress and it gives the same error
thru ip adress opening in web
idk what that is
Complete Logs
instead of an 16gb i used an 8gb stick....becouse i think my 126gb has a virus
its a raspberry pi 3 v1.2 connecting to my ender 3
The error you get has nothing to do with your IP connection.
It says, that the connection between OctoPrint on the Pi and printer via USB can not be established.
Some words in your post a written in blue - these are links to help you further. So please also share the logs. The serial log may be enabled first.
Also it would be quite handy to know what printer you want to connect.
an ender 3, can you explain in 2 words what i need to do to connect it to pronterface... cuz its like 30min to read that page, just tell me what to do becouse im a total noob and this thing doesnt run from the first try
You download this: https://github.com/kliment/Printrun/releases/download/printrun-1.6.0/Printrun-win-18Nov2017.zip , unpack it and start the pronterface.exe
You connect the printer to the PC via USB.
You click Connect
If this does not work instandly, you may have to change the Port and/or the Baudrate (@).
If the the connection is properly established, on the right side of Pronterface you get the connection report.
