I ask for help because I've been trying to get the webcam to work for days and I can't.
I state that the webcam works both on pc and before on rasberry which now I no longer have.
I installed on an octocitric orangepi 3lts and everything works perfectly except the webcam. I enabled the service I modified the octopi.txt file (through filezille because through ssh it doesn't save the file) and nothing at all I can't get anything to work. every time i go to http://myip/webcam/?action=stream always and usual error "" The webcam server is currently not running
If you do not have a camera attached, this is normal and can be safely ignored.ect ect"" via lsusb I have this
root@citrico-opi3lts:~# lsusb
Bus 006 Device 002: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 05e3:0626 Genesys Logic, Inc. USB3.1 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0483:5740 STMicroelectronics Virtual COM Port
Bus 001 Device 003: ID 1b3f:2002 Generalplus Technology Inc. 808 Camera
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
HELPME please ![]()
