Changed from Pi zero W to pi4b external
Checked my wiring for tx and rx, Also tried restoring from backup, enabled logging for connection
Serial log : 2021-10-19 13:51:33,075 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2021-10-19 13:52:42,883 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2021-10-19 13:54:54,971 - Enabling serial logging
2021-10-19 13:54:57,830 - Changing monitoring state from "Offline" to "Opening serial connection"
2021-10-19 13:54:57,832 - Connecting to port /dev/ttyAMA0, baudrate 115200
2021-10-19 13:54:57,853 - Changing monitoring state from "Opening serial connection" to "Connecting"
2021-10-19 13:54:57,855 - Connected to: Serial<id=0xa3b03210, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2021-10-19 13:54:57,858 - Send: N0 M110 N0*125
2021-10-19 13:54:57,898 - Unexpected error while reading serial port, please consult octoprint.log for details: OSError: '[Errno 25] Inappropriate ioctl for device' @ comm.py:_readline:3940
2021-10-19 13:54:57,900 - Changing monitoring state from "Connecting" to "Offline after error"
2021-10-19 13:54:57,901 - Connection closed, closing down monitor
Octoprint log:
2021-10-19 13:52:39,661 - octoprint.plugins.errortracking - INFO - Initialized error tracking
2021-10-19 13:52:42,906 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2021-10-19 13:52:42,909 - octoprint.util.comm - INFO - Connecting to port /dev/ttyAMA0, baudrate 115200
2021-10-19 13:52:42,941 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2021-10-19 13:52:42,944 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 3940, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 6592, in readline
self._buffered += self.read(self.in_waiting)
File "/home/pi/oprint/lib/python3.7/site-packages/serial/serialposix.py", line 549, in in_waiting
s = fcntl.ioctl(self.fd, TIOCINQ, TIOCM_zero_str)
OSError: [Errno 25] Inappropriate ioctl for device
2021-10-19 13:52:42,950 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-10-19 13:52:42,979 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline after error"
2021-10-19 13:52:42,985 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-10-19 13:54:57,830 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2021-10-19 13:54:57,832 - octoprint.util.comm - INFO - Connecting to port /dev/ttyAMA0, baudrate 115200
2021-10-19 13:54:57,854 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2021-10-19 13:54:57,856 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
2021-10-19 13:54:57,858 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-10-19 13:54:57,900 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline after error"
2021-10-19 13:54:57,906 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
The weird thing is that I can see the camera streaming clearly, however i cant communicate witht he printer itself.....
