Is there anyway to control the IR sensor on the OV5647 Webcam? I looked everywhere. Even in octopi.txt. The camera automatically switches when the room is completely dark. But in the day time with a little bit of light coming through it does not switch over. I can barely see the printer without it on. I messed with it yesterday and if I turn the camera enough it will turn on but then half the build plate is cut off. I am looking to turn maybe the sensitivity on the sensor or be able to manually turn it on if possible. Thank you for any help.
-Frank
